Alphacool VPP Apex Pump - G1/4 inner thread including Eisdecke D5 - Acetal V.3
- Article no.: 13305
- EAN: 4250197133050
- Weight: 1 kg
The Alphacool VPP Apex pump including the Eisdecke D5 Acetal V.3 combines powerful PWM-controlled pump technology with a versatile pump top. Three inlets, two outlets, and a stable mounting base allow for flexible integration into any custom loop system.
With the Eisdecke D5 Acetal V.3, the Apex VPP pump receives a housing that impresses both functionally and visually. The Eisdecke offers maximum flexibility in tube routing with a total of three inlets and two outlets. The new bracket ensures a stable stand and also allows installation in a 3.5" drive bay.
The Apex VPP is based on the well-known D5 format but has been significantly improved in key areas. Instead of a spherical bearing, it uses a ceramic shaft, which increases smooth operation and significantly reduces vibrations. Thanks to the redesigned coil layout, power consumption has been nearly halved.
Power is supplied via a modern SATA connector. The 4-pin PWM connector allows precise control and monitoring of the pump’s speed – ideal for users who demand full control over their system.
Optionally, the pump unit can be expanded into a complete pump/reservoir combo by adding a separately available reservoir top – perfect for compact and high-performance water cooling setups.
Technical data: Apex VPP Pump | |
Dimensions (L x W x H) | 65 x 65 x 41mm |
Material pump | synthetic material |
Material pump cover | aluminium |
Material axle | ceramics |
Connections | 4-Pin PWM | SATA |
Rotational speed | 2500 - 4500 RPM |
Cable lengths | 4-Pin PWM - 48cm | SATA - 48cm |
Operating voltage | 8-13V DC / 14W IP32 |
Starting voltage | 12V DC |
Maximum pumping head | 4,25m |
Maximum flow rate | 340L/h |
Maximum working temperature | 60°C |
Weight | 276g |
Color | black |
Technical data: Eisdecke D5 - Acetal V.3 | |
Dimensions (L x W x H) | 80 x 80 x 40mm |
Dimensions (L x W x H) with stand | 83 x 80 x 87mm |
Material | Acetal |
Threads | 5x 1/4" |
Warranty: 5 years
Dimensions: | 95 x 45 x 80mm |
Maximum discharge head: | Good (2 to 4m) |
Maximum system temperature: | 60°C |
Maximum flow: | 1500 l/h |
Possible control range: | 8-24V DC |
Color: | Black |
Tension: | 12V DC |
Power connection: | 4Pin |
Water outlet: | G1/4" internal thread |
Water inlet: | G1/4" internal thread |
Approved liquids: | Water/glycol mixture |
Power consumption: | 23W |
Material: | Ceramics, Plastic |
Liefertermin: in 2 - 3 Wochen
Liefertermin: in 8 - 9 Wochen
