power supply coupling for 4-pole
![ZK Stromversorgungskupplung für 4Pol](https://aquatuning.shop-cdn.com/media/image/de/3c/68/82022_1j73NqCR8ML2rV_600x600..jpg)
- Article no.: ZK
- EAN: 4049469057275
- Weight: 0,02 kg
- Available:
For our hobbyists: 4-pin Molex connector.
This plug can be used to replace defective plugs. It can also be used as a basis to produce Y-connectors or extensions in your system without much effort. If you want to tidy up your system properly, for example to optimize the air flow or improve your cable management, there is no way around a DIY plug like this. Cables that are too long can be shortened and then fed back into the system using this plug. It is also possible to reduce the voltage output from 12 to 7 or even 5 volts by bending the connection cables - without an adapter. This is particularly interesting when operating fans that should run a little slower and therefore more quietly.
The assembly is child's play. The plug is sent in 2 components. The plastic plug itself and the tips with which the connection is made. The tips are simply inserted into the stripped cable end. The cable is tightened at the other end of the tips by pressing the tips together with pliers. This finished tip can now be pushed into the plastic plug. It now clicks into place and holds rock solid.
4 metal tips
1 plastic plug
![ZK Phobya ATX/VGA Power Connector Pin Stecker - 20 Stück EOL](https://aquatuning.shop-cdn.com/media/image/7e/fe/44/82383_177eaLAKaul8Em_200x200..jpg)
![SZ Alphacool Silicon Bending Insert 30cm für ID 1/2" / 13mm HardTubes - Blau](https://aquatuning.shop-cdn.com/media/image/77/3c/c1/1013191_1LMhcSPMAOJQ6p_200x200..jpg)
![KAB Alphacool Eiskamm X4 - 3mm clear - 4 Stück EOL](https://aquatuning.shop-cdn.com/media/image/c9/bf/e9/1013627_1xhPJExRXaLfRc_200x200..jpg)
![KAB Alphacool Eiskamm X6 - 3mm clear - 4 Stück EOL](https://aquatuning.shop-cdn.com/media/image/11/59/1b/1013628_1Y2ijwNPMfCAwz_200x200..jpg)
![ZK Phobya PSU Power Connector Pin Stecker - 20 Stück EOL](https://aquatuning.shop-cdn.com/media/image/ea/9e/f1/82386_16sRaxeSjLdP47_200x200..jpg)
![MKA Alphacool AlphaCord Sleeve 4mm - 3,3m (10ft) - Black (Paracord 550 Typ 3) 330cm](https://aquatuning.shop-cdn.com/media/image/58/57/44/1013684_1ImwE0Y1423Ra0_200x200..jpg)
![KAB Alphacool Eiskamm Alu X4 - 4mm black - 4 Stück EOL](https://aquatuning.shop-cdn.com/media/image/bd/5f/61/1013645_1nVAtJKF7I1oow_200x200..jpg)
![ZK Phobya PSU Power Connector Pin Buchse - 20 Stück](https://aquatuning.shop-cdn.com/media/image/cd/e8/50/82385_1sR8NJOpSLhVZK_200x200..jpg)
![ZK Phobya Fan Power Connector Pin Buchse - 20 Stück EOL](https://aquatuning.shop-cdn.com/media/image/3a/29/02/82384_16bPqKSO6eFCes_200x200..jpg)
![ZK Phobya VGA Power Connector 6Pin Stecker (6-eckig) inkl. 6 Pins - 2 Stück Black EOL](https://aquatuning.shop-cdn.com/media/image/ed/90/82/82379_1tPXjb6TJaHq7F_200x200..jpg)
![ZK Phobya VGA Power Connector 6+2Pin Stecker inkl. 8 Pins - 2 Stück Black EOL](https://aquatuning.shop-cdn.com/media/image/8c/21/6b/82355_1p6cCdZRDziNbv_200x200..jpg)
![ZK Phobya ATX Power Connector 4Pin Stecker inkl. 4 Pins - 2 Stück Black](https://aquatuning.shop-cdn.com/media/image/5a/19/31/82346_1kNrZZksoKZfzF_200x200..jpg)
![KAB Alphacool Mini USB auf Mainboard USB 5-Pin 40cm](https://aquatuning.shop-cdn.com/media/image/70/f7/ee/1023371_1_200x200..jpg)
![LK Alphacool Y-Splitter 3-Pin auf 4x 3-Pin 15cm](https://aquatuning.shop-cdn.com/media/image/7c/32/6a/1023131_01_200x200..jpg)
![ANS Alphacool Eiszapfen 13/10mm Anschraubtülle 90° drehbar G1/4 - 4pcs Set Deep Black](https://aquatuning.shop-cdn.com/media/image/aa/3d/46/1022485_1DYrNWrtaKb4bh_200x200..jpg)
![S13 Alphacool EPDM Tube 13/10 - Black 3m (9,84ft) Retailbox](https://aquatuning.shop-cdn.com/media/image/6c/ae/02/1021502_01_200x200..jpg)
![S13 Alphacool Schlauch AlphaTube HF 13/10 (3/8"ID) - Ultra Clear 3m (9,8ft) Retailbox 300cm](https://aquatuning.shop-cdn.com/media/image/2b/ba/c9/1019548_1KA2xVJXgo7bKU_200x200..jpg)
![KAB Alphacool Eis-Matrix Verbindungskabel - 10cm EOL](https://aquatuning.shop-cdn.com/media/image/93/89/81/1015637_1_200x200..jpg)
![MKA Alphacool AlphaCord Sleeve 4mm - 3,3m (10ft) - White (Paracord 550 Typ 3) 330cm](https://aquatuning.shop-cdn.com/media/image/e5/8a/a3/1013694_10LfepwbhI2Woi_200x200..jpg)
![MKA Alphacool AlphaCord Sleeve 4mm - 3,3m (10ft) - Imperial Red (Paracord 550 Typ 3) 330cm](https://aquatuning.shop-cdn.com/media/image/7f/83/cd/1013690_10r2lH4RoRQiw0_200x200..jpg)
![KAB Alphacool Eiskamm Alu X5 Flat - 4mm black - 4 Stück EOL](https://aquatuning.shop-cdn.com/media/image/a7/dd/96/1013653_1R92ngBDHHa5sT_200x200..jpg)
![KAB Alphacool Eiskamm Alu X4 Flat - 4mm black - 4 Stück EOL](https://aquatuning.shop-cdn.com/media/image/b9/59/37/1013652_17ZrgZQd3gfQIs_200x200..jpg)
![KAB Alphacool Eiskamm Alu X6 - 4mm black - 4 Stück EOL](https://aquatuning.shop-cdn.com/media/image/8a/e9/7a/1013646_1OnFw0P59aebsT_200x200..jpg)
![KAB Alphacool Eiskamm X24 - 3mm black - 2 Stück EOL](https://aquatuning.shop-cdn.com/media/image/da/d6/27/1013642_1_200x200..jpg)
![KAB Alphacool Eiskamm X14 - 3mm black - 4 Stück EOL](https://aquatuning.shop-cdn.com/media/image/66/e1/56/1013640_1d222Oaq6AOXTq_200x200..jpg)
