Alphacool Eiskamm X4 Flat - 3mm black - 4 pieces
  • 24758
  • 4250197247580
  • 0,1 kg
€0.99 * €3.99 * (75.19% Saved)
What is that?
Highlights
  • Nylon is flexible and cannot break
  • Easy installation without modifications
  • Simple and clean laying of cables
  • Material: Polyester
  • Variant: X4 Flat
  • Dimensions: 19 x 4.75 x 2mm
  • Color: Black
Scope of delivery
  • Alphacool Eiskamm X5 Flat - 3mm black - 4 pieces
Datasheet
Assembly instructions
75%
Alphacool Ice Comb X6 - 3mm black - 4 pieces
€0.99 * €3.99 *
75%
€0.99 * €3.99 *
75%
Alphacool Ice Comb X4 - 3mm black - 4 pieces
€0.99 * €3.99 *
€0.99 * €5.02 *
75%
€0.99 * €3.99 *
€0.99 * €5.02 *
Alphacool Ice Comb X14 - 3mm black - 4 pieces
€0.99 * €5.02 *
€0.99 * €5.02 *
67%
Alphacool Eiskamm X5 Flat - 3mm clear - 4 pieces
€0.99 * €2.99 *
63%
€1.58 * €4.28 *
€4.97 *
€3.78 *
€2.58 *
Alphacool fan cable 4-pin to 4-pin extension 30cm white
€2.58 *
€4.48 *
€2.48 *
Alphacool fan cable 4-pin to 4-pin extension 15cm
€1.98 *
€34.98 *
€4.97 *
€1.48 *
€5.48 *
56%
MKA Alphacool AlphaCord Sleeve 4mm - 3,3m (10ft) - Acid Purple (Paracord 550 Typ 3) 330cm EOL
Alphacool AlphaCord Sleeve 4mm - 3.3m (10ft) - Acid Purple (Paracord 550 Type 3) 330cm
€1.98 * €4.47 *
€0.99 * €5.02 *
88%
€0.99 * €8.00 *
86%
€0.99 * €6.96 *
83%
KAB Alphacool Eiskamm Alu X6 - 4mm black - 4 Stück PHT EOL
Alphacool Eiskamm Alu X6 - 4mm black - 4 pieces
€0.99 * €5.94 *
75%
Alphacool Eiskamm X4 Flat - 3mm clear - 4 pieces
€0.99 * €3.89 *
78%
€0.99 * €4.49 *
€0.99 *
