  • 24746
  • 4250197247467
  • 0,002 kg
€1.99 * €4.49 * (55.68% Saved)
Content: 4 Stück (€0.50 * / 1 Stück)
What is that?
Highlights
  • Nylon is flexible and cannot break
  • Easy installation without modifications
  • Simple and clean laying of cables
  • Material: Polyester
  • Variant: X14 Flat
  • Dimensions: 30.5 x 8 x 2mm
  • Color: Clear
Scope of delivery
  • Alphacool Ice Comb X14 Flat - 3mm clear - 4 pieces
Datasheet
Assembly instructions
PUZ Alphacool Klettmatte zur Pumpenbefestigung
Alphacool Velcro mat for pump attachment
€3.48 *
ZK Stromversorgungsstecker für 4Pin Molex
power connector for 4Pin Molex
€1.69 *
36%
KAB Alphacool Eiskamm Alu X4 - 4mm black - 4 Stück EOL
Content 4 Stück (€0.80 * / 1 Stück)
€3.19 * €5.02 *
49%
Content 4 Stück (€0.50 * / 1 Stück)
€1.99 * €3.89 *
60%
Alphacool Eiskamm X5 Flat - 3mm clear - 4 pieces
€1.19 * €2.99 *
49%
Alphacool Eiskamm X4 Flat - 3mm clear - 4 pieces
€1.99 * €3.89 *
49%
KAB Alphacool Eiskamm X4 - 3mm clear - 4 Stück EOL
Alphacool Ice Comb X4 - 3mm clear - 4 pieces
€1.99 * €3.89 *
49%
KAB Alphacool Eiskamm X24 - 3mm clear - 2 Stück EOL
Alphacool Ice Comb X24 - 3mm clear - 2 pieces
Content 2 Stück (€1.00 * / 1 Stück)
€1.99 * €3.89 *
€1.19 *
WAK Alphacool Core Geforce RTX 5080 Reference mit Backplate
Alphacool Core Geforce RTX 5080 Reference with backplate
€199.98 *
Liefertermin: in 2 - 3 Wochen
Alphacool Y-Splitter 4-Pin to 3x 4-Pin PWM 60cm white
Content 60 Zentimeter (€8.30 * / 100 Zentimeter)
€4.98 *
Alphacool Y-Splitter 4-Pin to 3x 4-Pin PWM 30cm white
€3.78 *
Alphacool Y-Splitter 4-Pin to 2x 4-Pin PWM 60cm white
€3.88 *
Alphacool Y-Splitter 4-Pin to 2x 4-Pin PWM 30cm white
€2.98 *
Alphacool Y-Splitter 4-Pin to 2x 4-Pin PWM 15cm white
€2.58 *
Alphacool Y-Splitter aRGB 3-Pin to 4x 3-Pin 60cm
€6.99 *
Alphacool Y-Splitter aRGB 3-Pin to 4x 3-Pin 30cm
€5.99 *
Alphacool Y-Splitter aRGB 3-Pin to 4x 3-Pin 15cm
€5.68 *
Alphacool Y-Splitter aRGB 3-Pin to 3x 3-Pin 15cm
€4.48 *
Alphacool Y-Splitter aRGB 3-Pin to 3x 3-Pin 60cm
€5.99 *
Alphacool Y-Splitter aRGB 3-Pin to 2x 3-Pin 60cm
€4.68 *
Alphacool Y-Splitter aRGB 3-Pin to 2x 3-Pin 30cm
€3.97 *
Liefertermin: in 8 - 9 Wochen
Alphacool Y-Splitter aRGB 3-Pin to 2x 3-Pin 15cm
€3.47 *
€2.98 *
€2.78 *
€2.58 *
€1.68 *
€1.48 *
Alphacool fan cable 3-Pin to 3-Pin extension 60cm
€2.48 *
Alphacool fan cable 3-Pin to 3-Pin extension 30cm
€2.28 *
Alphacool fan cable 3-Pin to 3-Pin extension 15cm
€1.98 *
€4.38 *
Content 2 Stück (€14.99 * / 1 Stück)
€29.98 *
Content 6 Stück (€2.16 * / 1 Stück)
Alphacool Eiszapfen angle adapter 90° rotatable G1/4 AG to G1/4 IG - 4pcs Set Chrome
Content 4 Stück (€6.25 * / 1 Stück)
€24.98 *
€6.28 *
