Alphacool ice case - measuring tool 190mm
- Article no.: 90358
- EAN: 4250197136921
- Weight: 0,021 kg
- Available: Currently there are 3 available - More is on the way
Measuring tool 190mm For measuring the distances between the fittings that you want to... more
For measuring the distances between the fittings that you want to connect. You can also connect the measuring tongues to each other or mount them on the bending plate to transfer measurement results.
Content
30 Zentimeter
(€26.60 * / 100 Zentimeter)
€7.98
Content
30 Zentimeter
(€29.93 * / 100 Zentimeter)
€8.98
Content
6 Stück
(€6.66 * / 1 Stück)
€39.98
Content
320 Zentimeter
(€9.06 * / 100 Zentimeter)
€28.98
