Alphacool Eiskoffer - Angle feeder 16mm in 90°
ZSO Alphacool Eiskoffer - Winkelanleger 16mm in 90°
  • 90372
  • 4250197137171
  • 0,021 kg
90° bending feeder 2 versions for 3 dimensional bending Pipes with Ø 16 mm The horizontal... more
Pipes with Ø 16 mm
The horizontal angle can be freely adjusted by 180°. To do this, loosen the rear M4 screws using the included hexagon socket and set the required angle using the 1° scale. Then tighten the screws again.
Choose the right version according to the diameter of your chosen pipes.
manual
€28.98 *
€41.98 * €59.98 *
€5.99 *
Delivery date: in 2 - 3 days
€1.98 *
