Alphacool ice case - measuring tool 190mm
ZSO Alphacool Eiskoffer - Messwerkzeug 190mm
  • 90358
  • 4250197136921
  • 0,021 kg
Measuring tool 190mm For measuring the distances between the fittings that you want to... more
For measuring the distances between the fittings that you want to connect. You can also connect the measuring tongues to each other or mount them on the bending plate to transfer measurement results.
manual
62%
hose cutter aluminum replacement blade 3-19mm
€0.99 * €2.59 *
€39.98 *
€28.98 *
€1.78 *
