Alphacool Aurora HardTube LED Ring 13mm Chrome - Digital RGB
  • 15364
  • 4250197153645
  • 0,016 kg
S13 Alphacool HardTube 13/10mm Acrylic (PMMA) Clear 80cm - Set of 4 (320cm)
€19.98*
S16 Alphacool HardTube 16/11mm borosilicate glass 60cm
€23.98*
S13 Alphacool Ice Tube 13/10mm PETG HardTube 80cm - Set of 4 (320cm)
€21.98*
AGZ Alphacool Aurora LED Ring 60mm - Digital RGB
€22.98*
WACZ Alphacool Aurora XPX Digital RGB Frame - Black EOL
€6.99*
Get 10% off during Alphacool Black Friday Week. The discount will be visible in your shopping cart.
*1 Offer valid until 01/12/2025
The new Aurora HardTube LED rings with addressable RGB connection offer you the best modding... more
The new Aurora HardTube LED rings with addressable RGB connection offer you the best modding options to control and stage your system like a pro.
Optics at its finest
The new aRGB technology gives you the option to illuminate your entire system with different color modes. This makes your gaming system a real eye-catcher at any LAN party or simply at home.
Alphacool offers compatibility
With the new LED rings from Alphacool you can illuminate all HardTubes or hoses with 13mm or 16mm outer diameter and thus equip a variety of different systems, just as you want.
The power connection is made via a 3-pin JST connector. For direct connection to a mainboard, a 3-pin JST to 3-pin aRGB adapter is required.
Technical data:
  • Inner diameter: 13 mm
  • Outer diameter: 22 mm
  • Case length: 20 mm
  • LEDs: Digital addressable RGB LEDs
  • Connector: 3-pin
  • Cable length: 75 cm
Dimensions: 75 cm
ZSO Alphacool Tasse schwarz
Alphacool mug black
€2.98 *
Content 4 Stück (€4.20 * / 1 Stück)
€16.78 *
Alphacool EPDM Tube 13/10 - Black 1m (3.28ft) Retailbox
Alphacool Eiszapfen angle adapter 90° rotatable G1/4 AG to G1/4 IG - 4pcs Set Chrome
Content 4 Stück (€6.75 * / 1 Stück)
€26.98 *
€6.28 *
Alphacool Eiszapfen Pro 13mm Spare Parts
Content 10 Stück (€0.17 * / 1 Stück)
€1.68 *
RAD Alphacool NexXxoS HPE-30 Full Copper 420mm Radiator
€129.98 *
Delivery date: in 2 - 3 weeks
