Alphacool Core Geforce RTX 4080 Reference Design with Backplate
- Article no.: 13439
- EAN: 4250197134392
- Weight: 1,754 kg
- Verfügbar:
Attention! For PNY GeForce RTX 4080 the rear part of the PCB is not covered. This has no negative effect on the cooling performance
Note: The Inno3D GeForce RTX 4080 SUPER X3 is only compatible with the OC variant!
- Inno3D GeForce RTX 4080 iCHILL X3, 16GB GDDR6X (C40803-166XX-187049H)
- Inno3D GeForce RTX 4080 X3 OC, 16GB GDDR6X
- Inno3D GeForce RTX 4080 X3, 16GB GDDR6X
- PNY GeForce RTX 4080 16GB Verto Triple Fan, 16GB GDDR6X (VCG408016TFXPB1)
- Inno3D GeForce RTX 4080 SUPER iCHILL Black, 16GB GDDR6X (C408SB-166XX-18700006)
- Inno3D GeForce RTX 4080 SUPER iCHILL Frostbite, 16GB GDDR6X (C408S-166XX-1870FB)
- Inno3D GeForce RTX 4080 SUPER iCHILL X3, 16GB GDDR6X (C408S3-166XX-187049H)
- Inno3D GeForce RTX 4080 SUPER X3 OC, 16GB GDDR6X (N408S3-166XX-187049N)
Technical data cooler | |
Dimensions (L x W x H) | 201,36 x 145,90 x 32,80mm |
Threads | 4 x G1/4" |
Thickness cooler bottom | 11,3mm |
Illumination | digital aRGB LEDs |
Number of digital aRGB LEDs | 11 |
Color | transparent |
Technical data backplate | |
Dimensions (L x W x H) | 201,36 x 122,90 x 5mm |
Material | aluminium |
Color | black |
SLI kompatibel: | Ja |
Kühlertyp: | Komplettkühler |
Anschluss: | 4x G1/4" |
Material Deckel: | Acryl |
Abmessungen: | 201,36 x 145,90 x 32,80mm |
Hinweis: | Kompatibel bis 16/13mm gerade, Kompatibel bis 19/13mm gewinkelt |
Hardware Modell: | RTX 4080 |
Liefertermin: in 8 - 9 Tagen
Liefertermin: in 2 - 3 Wochen
