Alphacool Core Geforce RTX 4090 Reference Design with Backplate
- Article no.: 13394
- EAN: 4250197133944
- Weight: 2,014 kg
Important note: The RTX 4090 Core Reference cooler is not compatible with Nvidia's Geforce RTX 4090 Founders Edition. The RTX 4090 FE is compatible with the following cooler: Alphacool Core Geforce RTX 4090 Founders Edition with Backplate (Art. 13470).
Attention: Please note that a part of the PCB is not covered from the water block
Attention: Unfortunately Inno3D is using two different PCB Layouts. Please check your serial number. If it looks like following, it is not compatible with our water blocks: 32-879-xxxx8xxxx
_________________________________
- Inno3D GeForce RTX 4090 iCHILL Black, 24GB GDDR6X (C4090-246XX-18330005)
- Inno3D GeForce RTX 4090 iCHILL Frostbite, 24GB GDDR6X (C4090-246XX-1833FB)
- Inno3D GeForce RTX 4090 iCHILL X3, 24GB GDDR6X (C40903-246XX-1833VA47)
- Inno3D GeForce RTX 4090 X3 OC, 24GB GDDR6X (N40903-246XX-18332989)
- PNY GeForce RTX 4090 XLR8 Gaming Verto Epic-X RGB Overclocked Triple Fan, 24GB GDDR6X (VCG409024TFXXPB1-O)
- PNY GeForce RTX 4090 XLR8 Gaming Verto Epic-X RGB Triple Fan, 24GB GDDR6X (VCG409024TFXXPB1)
| Technical data cooler | |
| L x W x H | 222.36 x 145.85 x 32.65 mm |
| Pressure tested | 0.8 bar |
| Threads | 4 x G 1/4 |
| Thickness cooler bottom | 11.3 mm |
| Thickness cooling fins | 0.4 mm |
| Distance cooling fins | 0.4 mm |
| Power digital aRGB LEDs | 5 V |
| Number of digital aRGB LEDs | 12 |
| L x W x H | 222.36 x 122.85 x 5.78 mm |
| Material | aluminium |
| Color | black |
