Alphacool Eisblock Aurora Acryl GPX-N RTX 3070 with Backplate (Reference)
  • 11934
  • 4250197119344
  • 1,128 kg
€39.98 *
€18.98*
ANZ Alphacool Eiszapfen screw plug V.2 G1/4 - Deep Black
€3.48*
€37.98*
€18.98*
€6.49*
The Alphacool Eisblock Aurora Acrylic GPX graphics card water cooler with backplate combines... more
Important note: The Reference cooler is not compatible with Nvidia's Founders Edition.
More performance!
During the development of the Eisblock Aurora Acryl GPX graphics card water cooler, emphasis was naturally placed on increasing performance. First, the cooler was brought closer to the individual components by reducing the thickness of the heat conducting pads. Next, the chrome-plated copper block was also made thinner. Step 3 involves the constant optimisation of the water flow within the cooler. The result: All important components such as voltage converters and RAM are cooled much better and more effectively by the water and the cooling performance increases significantly.
Brilliant design!
Copper or aluminium?
Alphacool uses only copper for all water-bearing parts. Copper has almost twice the thermal conductivity of aluminum and is therefore clearly the better choice of material for water cooling. The cooler is made entirely of chrome-plated copper. A chrome plating is much harder than a nickel plating and therefore less sensitive to acids, scratches and damage. It completely eliminates the risk of chipping nickel plating. Additionally, chrome plating looks much more homogeneous and provides a shine that cannot be achieved by nickel plating.
Other special features
- Inno3D GeForce RTX 3070 iCHILL X3, 8GB GDDR6 (C30703-08D6X-1710VA38)
- Inno3D GeForce RTX 3070 iCHILL X4, 8GB GDDR6 (C30704-08D6X-1710VA35)
- Inno3D GeForce RTX 3070 Twin X2 OC, 8GB GDDR6 (N30702-08D6X-1710VA32L)
- Inno3D GeForce RTX 3070 Twin X2, 8GB GDDR6 (N30702-08D6-1710VA32L)
Technical data cooler
L x W x H239 x 122 x 25mm
Material cooler topacrylic
Threads4 x G1/4
Thickness cooling fins0,6 mm
Illuminationdigital aRGB LEDs
Power digital aRGB LEDs5V
Number of digital aRGB LEDs11
Technical data backplate
L x W x H239 x 97 x 6mm
Materialaluminium
Alphacool Eiszapfen 16/10mm compression fitting 90° rotatable G1/4 - 4pcs Set Deep Black
Delivery date: in 7 - 8 days
33%
€5.99 * €8.98 *
€6.49 * €8.98 *
Delivery date: in 8 - 9 weeks
WAGZ Alphacool GPU Terminal flat straight - Acetal
€36.98 *
Content 240 Zentimeter (€7.49 * / 100 Zentimeter)
AGB Alphacool Cape Corp Coolplex Pro 25 LT
and Conditions Alphacool Cape Corp Coolplex Pro 25 LT
€36.98 *
