- Article no.: 17484
- EAN: 4250197174848
- Weight: 0,243 kg
*1The new Eiszapfen PRO HardTube fittings from Alphacool are a further development of the well-known Eiszapfen. When developing the fittings, Alphacool focused specifically on a specific problem: the deformation of PETG HardTubes at high temperatures. These can deform at as little as 60°C. Although such a temperature is rarely reached, it can still occur. The Eiszapfen PRO prevent this problem from the outset and hold the tubes in position.
| Technical data | |
| material | Brass |
| Color | White |
| Height | 23mm |
| diameter | 26mm |
| Thread length | 5mm |
| thread | G1/4“ |
| HardTube Size | 16mm |
| compatibility | PETG, acrylic, brass and glass tubes |
| Weight | 42g |
Download data sheet PDF: Alphacool Eiszapfen PRO 16mm HardTube Fitting G1/4 - White Sixpack
Fitting Map: Here you will find an interactive overview of all Alphacool connections.
