Alphacool Eiszapfen 2-way ball valve G1/4 - White
  • 17630
  • 4250197176309
  • 0,092 kg
ANF Alphacool Eiszapfen double nipple rotatable G1/4 AG to G1/4 AG - White
€3.97*
17624 Alphacool Eiszapfen 13/10mm compression fitting G1/4 - white sixpack
€35.98*
17625 Alphacool Eiszapfen 16/10mm compression fitting G1/4 - white sixpack
€35.98*
17628 Alphacool Eiszapfen angled adaptor double-45° rotatable G1/4 outer thread to G1/4 inner thread - white
€12.98*
Alphacool's Eiszapfen series is future-oriented and characterized by excellent workmanship and... more
Alphacool's Eiszapfen series is future-oriented and characterized by excellent workmanship and high flow.
Ball valves have always been a flow brake, making life difficult for each pump. Then, Alphacool has developed a ball valve represents no obstacle to a diameter of 10mm.
The inside scoop closes absolutely tight, thus preventing further escape of liquid. On both sides all 1/4“ connections with a maximum thread length of 6mm can be screwed.
Dimensions (L x W x H)35,4 x 36 x 22,7mm
Thread1/4"
Inner diameter10mm
Colorwhite
€41.98 *
€38.98 *
€25.98 *
€28.98 *
€26.98 *
