Alphacool ice cyclone Aurora LUX PRO 2 Digital RGB (120x120x25mm)
- Article no.: 24808
- EAN: 4250197135979
- Weight: 0,175 kg
The Alphacool Eiszyklon Aurora LUX Pro 2 fan is also used on the Alphacool Eisbaer Aurora series and offers a wide control range as well as outstanding digital RGB LED lighting. The individually controllable 5V aRGB LEDs paired with the special design of the fan frame create unique effects.
Brilliant lighting
Digitally addressable 5V RGB LEDs are installed in the frame, which illuminate the entire frame on both sides. The frame is not completely transparent, but rather the lighting comes from narrow slits that are interrupted at four points. There are two rows of these slit-shaped recesses on the top. One narrow frame runs along the inside and one along the outside of the frame. This creates a unique lighting that looks very classy. Thanks to the embedded diffusers, the light is distributed evenly. This avoids spot lighting. Individual LEDs are no longer visible.
Wide control range and silent
The fan can be controlled from 700 to 2000 rpm via the 4-pin PWM connection. At 700 rpm, the fan is almost silent, but still offers a good air flow coupled with a high static pressure. This means that the fan can also be used very well on radiators for water cooling. Thanks to the high air flow, the fan is also ideal for ventilating a case. There are also decouplers directly on the frame. The soft foam padding reduces the transmission of vibrations to the case. Another plus point for the fan's silent capabilities.
Connections?
The fan is controlled via a 4-pin PWM connection. The cable is 50 cm long. This means that the fan can be connected to the mainboard or a special controller without any additional adapter cables or extensions. The digital aRGB LED lighting is controlled via a JST 3-pin connector.
- L x W x H: 120 x 120 x 25mm
- Speed: 700 - 2000 rpm
- Static pressure: 2.0 mm H2O
- Air flow: 104.49 m³/h
- Bearing: Hydraulic
- Fan connector: 4-pin PWM
- aRGB connector: 3-pin JST + 3-pin 5V
- LEDs: Addressable Digital RGB LEDs
- Volume: 21.5 - 33.8 dB(A)
- MTBF: 40,000 hours
- LEDs: 16x RGB LEDs
Download data sheet PDF: Alphacool Eiszyklon Aurora LUX PRO 2 Digital RGB fan
