Alphacool Core 1 LT Aurora Acrylic
  • 13886
  • 4250197138864
  • 0,67 kg
  • 5
€84.98 *
€31.98*
13441 Alphacool Eisblock Aurora Acryl GPX-N RTX 4080 Reference Design with Backplate
€49.98*
13548 Alphacool Eisblock Aurora Acryl RX 7900XT Reference with Backplate
€99.98*
€22.98*
With the Core 1 LT, Alphacool presents the light version of the proven Core 1 CPU water cooler.... more
With the Core 1 LT, Alphacool presents the light version of the proven Core 1 CPU water cooler. Housed in a polymer casing, the Core 1 LT also uses the reliable combination of 3D jetplate and cross slot-technology. This enables it to effectively dissipate the enormous waste heat of the latest desktop processors. With its elegant design, it integrates seamlessly into any water cooling system. The new mounting system is also included and simplifies installation with Intel and AMD processors.
The best of new and old
Alphacool combines the best of both worlds with the Core 1 water cooler series. In addition to the new 3D jetplate, Alphacool returns to its roots by distributing the coolant evenly across the redesigned cooler base using proven cross-slot technology. Inside the cooler, O-rings ensure a precise water flow and thus guarantee effective cooling. The nickel-plated copper base of the cooler has been enlarged to achieve full coverage of large CPUs.
New Mounting System
Core Design
The functional and elegant design is a central element of the Core series from Alphacool. Its focus is on cooling performance at a fair price. The rounded corners add the perfect touch to the overall look. The Core 1 LT is available in both non-illuminated and transparent aRGB versions.
- Attention: The Eiszapfen PRO 16mm HardTube fittings cannot be used with this CPU cooler!
AMD: AM4 / AM5
Intel: LGA 1700 / LGA 1851
Dimensions (L x W x H)71.80 x 71.80 x 28.05mm
Material cooler topacrylic
Material threadsacrylic
Threads2 x G1/4“
Fin thickness0.4mm
Fin distance0.4mm
Pressure tested0.8 bar
Max working temperature60°C
Weight250g
Colortransparent/black
Warranty: 5 years
Awards & Videos
Delivery date: in 5 - 6 weeks
€37.98 *
€20.98 *
€6.49 * €8.98 *
