Alphacool Eiswasser Crystal Green UV-active premixed coolant 1000ml
- Article no.: 18545
- EAN: 4250197185455
- Weight: 1,1 kg
| Technical data | |
| Content | 1000ml |
| Specification | Ready mix |
| Color | green |
| UV ink | green |
| Manufacturer | Alphacool |
