Alphacool Eisfluegel flow indicator black G1/4 IG - acrylic
  • 17366
  • 4250197173667
  • 0,04 kg
WAZ Alphacool Ice Water Crystal Yellow Ready Mix 1000ml
€12.98*
WAZ Alphacool Ice Water Crystal Clear UV-active Ready Mix 1000ml
€12.98*
Alphacool Eisflügel: The flow indicator with added value! Water cooling in a computer always... more
Water cooling in a computer always serves to improve the appearance. Neatly laid hoses or hard tubes create an impressive image. The Alphacool ice wing can also be used to create a real eye-catcher. The silent rotation of the impeller always shows the direction of flow.
  • Dimensions: 69.5 x 41 x 17mm
  • pressure load up to 2 bar, max.
  • Connection: for all G1/4" connections
  • Material: ABS
Scope of delivery
  • 1x Alphacool Eisfluegel flow indicator black G1/4 IG - acrylic
WZS Spritzflasche 500ml PE-LD
spray bottle 500ml PE-LD
€4.19 *
€34.98 *
SZ Schlauchabschneider
hose cutter
€6.29 *
Content 4 Stück (€7.00 * / 1 Stück)
€27.98 *
€6.28 *
Content 2 Stück (€12.49 * / 1 Stück)
€24.98 *
€6.49 * €8.98 *
17%
€14.98 * €17.98 *
Content 6 Stück (€2.66 * / 1 Stück)
14%
PUZ Alphacool Pumpenbefestigung Universal für 120-140er Lüfter/Radiatoren
Alphacool pump mount universal for 120-140mm fans/radiators
€11.98 * €13.99 *
