Alphacool Mini USB to Mainboard USB 5-Pin 40cm
KAB Alphacool Mini USB auf Mainboard USB 5-Pin 40cm EOL
  • 18717
  • 4250197187176
  • 0,015 kg
€2.98 *
Content: 40 Zentimeter (€7.45 * / 100 Zentimeter)
KAB Alphacool Ice Matrix connection cable - 10cm EOL
€0.99*
€15.98*
KAB Alphacool Digital RGB LED Y-cable 3-way with JST connector - black 60cm
€7.98*
KAB Alphacool Eis-Matrix II - Adapter 5-Pin to PWM + 5V Digital RGB (3pcs) each 20cm EOL
€4.47*
High quality Mini USB to motherboard USB 5-pin cable with 40cm length for connecting electronic... more
High quality Mini USB to motherboard USB 5-pin cable with 40cm length for connecting electronic components. For example for mounting USB devices inside the case like fans/RGB controllers.
Length40cm
ConnectionsMini USB to mainboard USB 5-pin
Weight11g
54%
Alphacool RGB 4-pin LED adapter cable for motherboards - Black 50cm
Content 50 Zentimeter (€3.96 * / 100 Zentimeter)
€1.98 * €4.28 *
83%
Alphacool Y-cable RGBW 5-pin to 3x 5-pin incl. connector - black 30cm
Content 30 Zentimeter (€3.30 * / 100 Zentimeter)
€0.99 * €5.89 *
€5.99 *
€2.28 *
€34.98 *
Alphacool M3 spacer 34mm
€3.98 *
56%
Alphacool AlphaCord Sleeve 4mm - 3.3m (10ft) - White (Paracord 550 Type 3) 330cm
€1.98 * €4.47 *
