Phobya Y-Adapter 4Pin Molex auf 2x 4Pin PWM und 3Pin - Schwarz 30cm
- Article no.: LK
- EAN: 4049469136185
- Weight: 0,019 kg
A Y-cable for connection of a 1x 3-Pin and 2x 4-Pin PWM fan to a 4-Pin Molex connector.
On this connector / adaptor cable the 4-Pin Molex connector is looped through, hence this adaptor does not even block a connector!
Sleeving:
The idea behind these cables:
Technical specifications:
Connectors: 4-Pin Molex to 1x 3-Pin and 2x 4-Pin (PWM) 12V
Black sleeve, black connectors and black heatshrink
Dimensions: 30cm overall
Extent of delivery:
1x Phobya Y-adaptor 4-Pin Molex to 2x 4-Pin PWM and 3-Pin 30cm - black
This product has been reviewed for you:
Aquainfos
Tech-Review
Sleeving: | schwarz |
Hersteller: | Phobya |
1. Seite: | 1x 4Pin Molex |
Bauform: | Y-Kabel |
2. Seite: | 3x 3Pin Molex |
Liefertermin: in 10 - 11 Tagen
Liefertermin: in 8 - 9 Wochen
