Alphacool Core Geforce RTX 5090 Gaming + Windforce with Backplate
  • 10293
  • 4250197102933
  • 1,904 kg
€219.98 *
S13 Alphacool HardTube 13/10mm Acrylic (PMMA) Clear 80cm
€7.98*
€37.98*
€35.98*
13886 Alphacool Core 1 LT Aurora Acrylic
€84.98*
- Gigabyte AORUS GeForce RTX 5090 MASTER 32G (GV-N5090AORUS M-32GD)
- Gigabyte AORUS GeForce RTX 5090 MASTER ICE 32G (GV-N5090AORUSM ICE-32GD)
- Gigabyte GeForce RTX 5090 GAMING OC 32G (GV-N5090GAMING OC-32GD)
- Gigabyte GeForce RTX 5090 WINDFORCE 32G (GV-N5090WF3-32GD)
- Gigabyte GeForce RTX 5090 WINDFORCE OC 32G (GV-N5090WF3OC-32GD)
Technical data cooler
Dimensions total (L x W x H)237,50 x 157,07 x 34,20mm
Material cooler topAcrylic
Material terminalNylon
Max working temperature60°C
Pressure tested0,8 bar
Threads4 x G1/4"
Thickness cooler bottom3,25mm
Thickness cooling fins0,4mm
Distance cooling fins0,4mm
Illuminationdigital aRGB LEDs
Power digital aRGB LEDs5V
Number of digital aRGB LEDs11
Colortransparent
Technical data backplate
Dimensions (L x W x H)237,50 x 128,50 x 6mm
Thick backplate without spacers3mm
MaterialAluminium
€2.28 *
