Alphacool Core Geforce RTX 5080 Aorus Master + Windforce with Backplate
- Article no.: 10290
- EAN: 4250197102902
- Weight: 1,441 kg
- Gigabyte GeForce RTX™ 5070 Ti AERO OC 16G (GV-N507TAERO OC-16GD)
- Gigabyte GeForce RTX™ 5070 Ti GAMING OC 16G (GV-N507TGAMING OC-16GD)
- Gigabyte GeForce RTX™ 5070 Ti WINDFORCE OC SFF 16G (GV-N507TWF3OC-16GD)
- Gigabyte GeForce RTX™ 5070 Ti WINDFORCE SFF 16G (GV-N507TWF3-16GD)
- Gigabyte AORUS GeForce RTX™ 5080 MASTER 16G (GV-N5080AORUS M-16GD)
- Gigabyte GeForce RTX™ 5080 AERO OC SFF 16G (GV-N5080AERO OC-16GD)
- Gigabyte GeForce RTX™ 5080 GAMING OC 16G (GV-N5080GAMING OC-16GD)
- Gigabyte GeForce RTX™ 5080 WINDFORCE OC SFF 16G (GV-N5080WF3OC-16GD)
- Gigabyte GeForce RTX™ 5080 WINDFORCE SFF 16G (GV-N5080WF3-16GD)
| Technical data cooler | |
| Dimensions total (L x W x H) | 205,50x 140,93 x 34,19mm |
| Material terminal | Nylon |
| Pressure tested | 0,8 bar |
| Threads | 4 x G1/4" |
| Number of digital aRGB LEDs | 8 |
| Color | transparent |
| Dimensions (L x W x H) | 205,50 x 112,40 x 6mm |
| Thickness backplate without spacers | 3mm |
| Material | Aluminium |
