Alphacool Core Geforce RTX 5080 Gaming Trio with backplate
- Article no.: 10276
- EAN: 4250197102766
- Weight: 1,466 kg
- MSI GeForce RTX™ 5070 Ti 16G GAMING TRIO OC
- MSI GeForce RTX™ 5070 Ti 16G GAMING TRIO OC PLUS (V531-058R)
- MSI GeForce RTX™ 5070 Ti 16G GAMING TRIO PLUS
- MSI GeForce RTX™ 5080 16G GAMING TRIO
- MSI GeForce RTX™ 5080 16G GAMING TRIO OC
- MSI GeForce RTX™ 5080 16G GAMING TRIO OC White
| Technical data cooler | |
| Dimensions total (L x W x H) | 180,50 x 151,07 x 34,20mm |
| Material terminal | Nylon |
| Pressure tested | 0,8 bar |
| Threads | 4 x G1/4" |
| Number of digital aRGB LEDs | 8 |
| Color | transparent |
| Dimensions (L x W x H) | 180,50 x 122,50 x 6,00mm |
| Thickness backplate without spacers | 3mm |
| Material | Aluminium |
Delivery date: in 7 - 8 weeks
