Alphacool Core Geforce RTX 5090 Solid + AMP with backplate
  • 14730
  • 4250197147309
  • 1,88 kg
€219.98 *
€19.98*
€37.98*
€35.98*
€125.98*
- Zotac Gaming GeForce RTX™ 5090 AMP Extreme Infinity (ZT-B50900B-10P)
- Zotac Gaming GeForce RTX™ 5090 Solid (ZT-B50900D-10P)
- Zotac Gaming GeForce RTX™ 5090 Solid OC (ZT-B50900J-10P)
Technical data cooler
Dimensions total (L x W x H)234,00 x 150,53 x 34,10mm
Material cooler topAcrylic
Material terminalAcetal
Max working temperature60°C
Pressure tested0,8 bar
Threads4 x G1/4"
Thickness cooler bottom3,25mm
Thickness cooling fins0,4mm
Distance cooling fins0,4mm
Illuminationdigital aRGB LEDs
Power digital aRGB LEDs5V
Number of digital aRGB LEDs11
Colortransparent
Technical data backplate
Dimensions (L x W x H)234,00 x 122,00 x 6mm
Thick backplate without spacers3mm
MaterialAluminium
€34.98 *
€33.98 *
€39.98 *
WAC Alphacool Core 1 Silver
