Alphacool Apex Distro Plate Y60 D5 with VPP Apex PWM pump
  • 13848
  • 4250197138482
  • 3,468 kg
€199.98 * €299.98 * (33.34% Saved)
18439 Alphacool HardTube 13/10mm Acryl clear 60cm - 4pcs
€15.98*
€37.98*
13394 Alphacool Core Geforce RTX 4090 Reference Design with Backplate
€69.98*
13834 Alphacool Core 1 Aurora White
€136.98*
The Alphacool Apex Distro Plate is the visual upgrade for the Y60. It was specially designed for... more
The Alphacool Apex Distro Plate is the visual upgrade for the Y60. It was specially designed for this case and replaces the front glass panel. A must-have for every custom water cooling system.
Apex Design
The Apex product line from Alphacool represents the highest level of perfection. First-class materials and innovative technologies guarantee a unique premium product. A core element is the chrome-plated brass G1/4" connections. In this way, Alphacool avoids the problem of possible leaks due to cracking caused by screwing the connections directly into the acrylic. The connections are in two parts, fitted with an O-ring and counter each other when installed in the acrylic.
High-quality choice of materials & brilliant lighting
Alphacool's Apex Distro Plate is made from high-quality acrylic glass. This allows a clear view of the coolant and enables brilliant illumination thanks to the built-in digitally addressable aRGB lighting. The lighting can be controlled via a digital aRGB header on the mainboard or optionally via Alphacool's Aurora Eiscontrol aRGB controller (article no.: 15360).
Easy installation
The Alphacool Apex Distro Plate Y60 replaces the front glass panel of the Y60 housing and is easy to install. It is mounted in place of the glass panel and securely fastened using the original screws. After installation, the distro plate is connected to the water cooling loop.
Note: The Apex Distro Plate Y60 is only compatible with the Y60 housing.
Attention: It is not possible to mount the Distro Plate if a 140 mm or 280 mm radiator is attached to the side.
- Y60 Case
Dimensions (L x W x H)344,50 x 213,50 x 87,30 mm
Materialacrylic
Volumeapprox. 300ml
Pump compatibilityVPP/D5
Threads6x G1/4" + 1x fill port and 1x drain port
Pressure tested0,8 Bar
Quantity digital aRGB LEDs11
Power digital aRGB LEDs5V
Power connection digital aRGB LEDs3-Pin JST + 3-Pin 5V
Weight3000g
Colortransparent
Technical data pump
Material pump coveraluminium
Material axleceramics
Connections4-Pin PWM | SATA
Cable lengths4-Pin PWM - 48cm | SATA - 48cm
Starting voltage12V DC
Maximum pumping head4,25m
Maximum flow rate340L/h
ANK Alphacool ES Distro Plate C3 PHT EOL
€41.98 *
Delivery date: in 7 - 8 days
ANK Alphacool ES Distro Plate C5 PHT EOL
€57.98 *
€25.98 *
€39.98 *
