Alphacool Ice Layer Thermal Pad - 17W/mK 120x20x0.5mm - 2 pieces
  • 12468
  • 4250197124683
  • 0,035 kg
€58.88 * €89.98 * (34.56% Saved)
Content: 48 cm² (€1.23 * / 1 cm²)
31%
€23.98 * €34.97 *
Content 100 cm² (€0.86 * / 1 cm²)
€86.28 * €119.98 *
21%
€33.97 * €42.98 *
31%
WÄM Alphacool Eisschicht Wärmeleitpad - 11W/mK 120x20x1,5mm - 2 Stück PHT EOL
Content 48 cm² (€0.41 * / 1 cm²)
€19.88 * €28.98 *
35%
WÄM Alphacool Eisschicht Wärmeleitpad - 11W/mK 120x20x1mm - 2 Stück PHT EOL
Content 48 cm² (€0.30 * / 1 cm²)
€14.38 * €21.98 *
