Alphacool Eisschicht Light thermal pad - 7W/mK 120x20x1mm
  • 12861
  • 4250197128612
  • 0,009 kg
€3.68 * €6.99 * (47.35% Saved)
Content: 24 cm² (€0.15 * / 1 cm²)
Alphacool's ultimate solution lets you cool your computer with a sheet of ice. Not an ice sheet... more
Alphacool's ultimate solution lets you cool your computer with a sheet of ice. Not an ice sheet in the conventional sense, made of frozen water, but a sheet that brings every chip down to freezing. The properties of these new thermal pads speak for themselves.
The light version of the Alphacool Eisschicht ("ice sheet") is the "small and weak" version at 7W/mK, but is definitely strong enough. Any hardware components can now be put together neatly and easily with thermal pads.
The Alphacool Eisschicht offers all the benefits and typical qualities of a thermal pad: self-adhesive, elastic, flexible, and much more! Just as varied are the options for placement: whether on RAM or motherboard coolers, or graphics card and CPU coolers, any place where chips meet cooler bodies is a good place for an Alphacool Eisschicht.
The Eisschicht Light, with a performance level of 7W/mK, is available in 0.5mm, 1mm, and 1.5mm thicknesses. Perfect for levelling height differences. Each thickness is also available in 100x100mm and 120x20mm (suitable for RAM coolers) sizes. These can easily be cut with scissors to get the right size for any component.
Dimensions (L x W x H)120 x 20 x 1mm
Thermal conductivity7W/mK
Colorpink
€0.98 *
€1.19 *
Alphacool Eisschicht Light thermal pad - 7W/mK 120x20x1,5mm
Content 24 cm² (€0.15 * / 1 cm²)
€3.68 * €4.97 *
33%
WÄM Alphacool Eisschicht Light Wärmeleitpad - 7W/mK 100x100x0,5mm PHT EOL
Alphacool Eisschicht Light thermal pad - 7W/mK 100x100x0,5mm
Content 100 cm² (€0.05 * / 1 cm²)
€5.38 * €7.98 *
€6.49 * €8.98 *
34%
WÄM Alphacool Eisschicht Light Wärmeleitpad - 7W/mK 120x20x0,5mm PHT EOL
Alphacool Eisschicht Light thermal pad - 7W/mK 120x20x0,5mm
Content 24 cm² (€0.17 * / 1 cm²)
€3.97 * €5.99 *
38%
43%
Alphacool Core Thermal Pad Soft 9W/mk 120x20x0,5mm
Content 24 cm² (€0.19 * / 1 cm²)
€4.58 * €7.98 *
33%
Alphacool Core Thermal Pad Soft 6.2W/mk 120x20x1mm
Content 24 cm² (€0.20 * / 1 cm²)
€4.68 * €6.99 *
27%
Alphacool Core Thermal Pad Soft 6.2W/mk 40x40x2mm
Content 16 cm² (€0.32 * / 1 cm²)
€5.08 * €6.99 *
€4.48 *
€5.99 *
€2.98 *
€2.78 *
€2.48 *
33%
€5.99 * €8.98 *
