Alphacool Core Thermal Pad Soft 6.2W/mk 40x40x1mm
- Article no.: 13408
- EAN: 4250197134088
- Weight: 0,019 kg
- Available: Currently there are 4 available - More is on the way
Increased service life!
Versatile use!
| Dimensions (L x W x H) | 40 x 40 x 1mm |
| Thermal Conductivity (ASTM D5470) | 6.2 W/mK (±10%) |
| Hardness (ASTM D412) | 50 (Shore 00) (±15) |
| Working temperature | -50 to ~150°C |
| Volume Resistance (ASTM D257) | 1×10¹³ Ohm-m |
| Dielectric Breakdown Voltage (ASTM D149) | 6 KV/mm (±10%) |
| Density (ASTM D792) | 3.1 g/cm³ (±10%) |
| Elongation (ASTM D412) | 50% |
| Color | blue |
