Alphacool Eisschicht Light thermal pad - 7W/mK 14x14x1mm
- Article no.: 12922
- EAN: 4250197129220
- Weight: 0,008 kg
*1Alphacool's ultimate solution for cooling your computer with a layer of ice. Not a layer of ice in the traditional sense made of frozen water, but a layer that will freeze any chip. The properties of the new thermal pads speak for themselves.
The Ice Layers Light are available in the 7W/mk power level in 0.5mm, 1mm and 1.5mm thicknesses. Perfect for compensating for height differences. Each thickness is also available in 100x100mm and 120x20mm (suitable for RAM coolers). These can be easily separated with scissors to individually adjust the right size for each component
| Technical data | |
| Dimensions (L x W x H) | 14 x 14 x 1mm |
| Thermal conductivity | 7W/mK |
| Color | pink |
