Alphacool Eisschicht thermal pad - 17W/mK 100x100x0,5mm
  • 12464
  • 4250197124645
  • 0,042 kg
€209.98 *
Content: 100 cm² (€2.10 * / 1 cm²)
Dimensions (L x W x H)100 x 100 x 0,5mm
Thermal conductivity17W/mK
Thickness0,5mm
Flame retardantV-0 (UL94)
Useful temperature-40 ~ +150 °C
Hardness72 (Shore OO)
Specific gravity3.2
Breakdown voltage10 kV/mm
Elongation40 %
Tensile strength0.5 MPa
Volume resistivity1.0x10^11 Ohm-m
Fasteningslightly adhesive
Colorgrey
Fastening: Slightly adhesive
Thickness: 0,5mm
Surface dimensions: 100 x 100mm
Thermal conductivity: 17W/mk
€0.98 *
€1.19 *
Alphacool Y-Splitter aRGB 3-Pin to 4x 3-Pin 60cm
€6.99 *
Alphacool Y-Splitter 4-Pin to 4x 4-Pin PWM 60cm
€5.28 *
22%
€46.98 * €59.98 *
Alphacool Eiszapfen angle adapter 90° rotatable G1/4 AG to G1/4 IG - 4pcs Set Chrome
Content 4 Stück (€6.75 * / 1 Stück)
€26.98 *
Alphacool Eiszapfen 16/10mm screw-on nozzle 90° rotatable G1/4 - 4pcs Set Chrome
€29.98 *
WAR Alphacool Eisschicht Wärmeleitpad - 17W/mK 120x20x1mm - 2 Stück PHT EOL
Alphacool Ice Layer Thermal Pad - 17W/mK 120x20x1mm - 2 pieces
Content 48 cm² (€1.87 * / 1 cm²)
€89.98 *
WAGZ Alphacool Eisschicht Wärmeleitpad - 17W/mK 100x100x1,5mm PHT EOL
Alphacool Eisschicht thermal pad - 17W/mK 100x100x1,5mm
Content 100 cm² (€2.40 * / 1 cm²)
€239.98 *
Alphacool D-RAM module (for Alphacool D-RAM cooler) - black 2 pieces
Content 2 Stück (€11.49 * / 1 Stück)
