Alphacool Eisschicht thermal pad - 17W/mK 100x100x1,5mm
  • 12467
  • 4250197124676
  • 0,077 kg
€190.07 *
Content: 100 cm² (€1.90 * / 1 cm²)
Dimensions (L x W x H)100 x 100 x 1,5mm
Thermal conductivity17W/mK
Thickness1,5mm
Flame retardantV-0 (UL94)
Useful temperature-40 ~ +150 °C
Hardness72 (Shore OO)
Specific gravity3.2
Breakdown voltage10 kV/mm
Elongation40 %
Tensile strength0.5 MPa
Volume resistivity1.0x10^11 Ohm-m
Fasteningslightly adhesive
Colorgrey
20% Cyber Monday
€0.98 *
20% Cyber Monday
€1.19 *
Content 50 Gramm (€1,399.60 * / 1000 Gramm)
€69.98 *
WAR Alphacool Eisschicht Wärmeleitpad - 17W/mK 120x20x1mm - 2 Stück PHT EOL
Alphacool Ice Layer Thermal Pad - 17W/mK 120x20x1mm - 2 pieces
Content 48 cm² (€1.48 * / 1 cm²)
€71.27 *
€39.98 *
