Alphacool Ice Layer Thermal Pad - 17W/mK 120x20x1mm - 2 pieces
- Article no.: 12469
- EAN: 4250197124690
- Weight: 0,05 kg
*1Alphacool's ultimate solution for cooling your computer with a layer of ice. Not a layer of ice in the traditional sense made of frozen water, but a layer that will freeze any chip. The properties of the new thermal pads speak for themselves.
