Alphacool Acryl Tube outer thread 60x84mm (DxH)
- Article no.: 15471
- EAN: 4250197154710
- Weight: 0,147 kg
- Available: Currently there are 4 available - More is on the way
Perfect replacement or practical extension. Does your Alphacool Core 100 or Core 200 need a visual upgrade or a functional adjustment? The replacement acrylic tube with external thread is the ideal solution to give your Core 100 / 200 a new shine or to customize the size.
With the Alphacool acrylic tube external thread 60x84mm you can easily give your water cooling system a new look or expand its functionality. Does your Core 100 no longer look so good because the acrylic tube has become scratched? Or do you have the Core 200 version and want to have the smaller Core 100 version? No problem! This high-quality spare part offers you exactly these options.
Simply unscrew the scratched or too small acrylic tube and fit the new one. You can continue to use the pump base and cover without any problems. This saves you time and effort - with an impressive result! Whether as a spare part or an extension: With the Alphacool acrylic tube external thread 60x84mm you get the best out of your water cooling system.
| Technical Data | |
| Dimensions (DxH) | 60x84mm |
| Color | Transparent |
| Material | Acrylic |
| Compatibility | Alphacool Core 100, Alphacool Core 200 |
