Alphacool Eisbecher Aurora D5 Acetal/Glass - 250mm incl. Alphacool VPP Apex
  • 13326
  • 4250197133265
  • 1,5 kg
€154.98 *
Delivery date: in 7 - 8 days
ANS Alphacool Eiszapfen 16mm HardTube screw-on nozzle G1/4 - Deep Black Sixpack
€33.98*
€34.98*
€14.98*
€69.98*
WZS Alphacool spray bottle Core 1000ml
€6.28*
ANS Alphacool Eiszapfen 16mm HardTube screw-on nozzle 90° rotatable G1/4 for acrylic/brass tubes - 4pcs
€33.98*
PUM Alphacool VPP655 - Single Edition PHT EOL
€69.98*
Alphacool VPP655 - PWM - Single Edition
€74.98*
The Alphacool Eisbecher Aurora reservoir has an integrated pump top for powerful D5 pumps and is... more
The Alphacool Eisbecher Aurora reservoir has an integrated pump top for powerful D5 pumps and is supplied with a VPP Apex pump. The reservoir tube is made of glass, the D5/VPP pump top and the lid are made of acetal. The combination of these two materials gives the reservoir a unique and elegant look. 12 digitally addressable RGB LEDs in the pump top and the light tower water effect inside the glass tube create the wow effect.
Extensive assembly options
Mounting option 1:
The scope of delivery includes feet which, among other things, enable the expansion tank to be mounted on the bottom of the housing.
Mounting option 2:
The scope of delivery includes 120mm/140mm mounting frames with which the Eisbecher Aurora expansion tank can be attached to any free fan slots, radiators or to the fans on radiators.
Digitally addressable RGB lighting
12 digitally addressable RGB LEDs illuminate the glass tube of the expansion tank. They are arranged in a ring at the lower end of the tube in the transition to the pump top and ensure brilliant illumination of the entire expansion tank. In combination with the Lighttower water effect, a very special ambience is achieved. Particularly through the reflections in the real glass. The digital aRGB LED lighting is connected via a JST 3-pin connector and can be controlled with a digital RGB controller (e.g. Alphacool Aurora Eiscontrol, Art.15360) or a digital RGB capable mainboard.
A special water effect is created in the ice cream sundae reservoir via the riser tubes. If you do not fill the expansion tank beyond the upper edge of the riser tube, you get a kind of fountain effect. The water is pushed out of the sides of the riser tube and sprayed against the glass tube. The effect is stronger or weaker depending on the flow of the circuit. The effect can be placed at the lower or upper inlet using the riser tubes included in the delivery.
pump
The VPP Apex pump does not have a spherical bearing and uses a ceramic axle. The motor coils have been moved from the inside to the outside. The changes mean that the pump is fundamentally more stable and runs more smoothly and vibrations have been significantly reduced. Another positive side effect is that power consumption has been almost halved. In comparison to Alphacool's ice pumps, the power supply is not via a 4-pin Molex connection. Instead, the Apex VPP pump is connected to the power supply using a SATA connection. The Apex VPP pump has a 4-pin fan connection that is connected to the mainboard or to an external controller. This allows the speed range of the pump to be controlled and read via PWM.
L x W x H 242x77x77mm
Pump compatibility D5
volume 360ml
Material pump top & lid Acetal
Material tube Glass
Material bridges aluminum
Connections 1x G1/4“ internal thread IN / 4x G1/4“ internal thread OUT
Maximum working temperature 60°C
Pressure tested 0.8 bars
Number of digital aRGB LEDs 12
Voltage digital aRGB LEDs 5V
Power connection digital aRGB LEDs 3-pin JST + 3-pin 5V
Weight 765g
Color black
Technical data VPP Apex
Dimensions (L x W x H) 65x65x41mm
Material pump plastic
Material pump cover aluminum
Material Axle Ceramics
Power connection 4-pin PWM | SATA
Control range 2500 - 4500 RPM
Cable lengths 4-Pin PWM - 48cm | SATA - 48cm
Operating voltage 8-13V DC / 14W IP32
Starting voltage 12V DC
Maximum discharge head 4.25m
Maximum flow 340 l/h
Net weight 276g
Color black
Made in: China
Maximum discharge head: Extreme (greater than 4m)
Maximum system temperature: 60°C
Maximum flow: 340 l/h
Color: Black
Tension: 12V DC
Power connection: SATA
Water outlet: G1/4" internal thread
Water inlet: G1/4" internal thread
Approved liquids: Water/glycol mixture
Power consumption: 14W
Material: Acetal, Aluminum, Ceramics, Plastic
€34.98 *
WZS Spritzflasche 500ml PE-LD
spray bottle 500ml PE-LD
€4.19 *
Alphacool Core 1 Aurora Black
€119.98 *
€33.98 *
€99.98 *
SZ Schlauchabschneider
hose cutter
€6.29 *
€33.98 *
WAC Alphacool Core 1 LT Aurora Acryl
Alphacool Core 1 LT Aurora Acrylic
€6.28 *
