Eheim 1046-790 230Volt full ceramic bearing
  • 1046740
  • 4011708105306
  • 0,594 kg
  • There are more than 5 units available
€52.99 *
PUZ Eheim 1046 outlet adapter to G1/8"
€3.89*
PUZ Eheim 1046/48 inlet and 1250 outlet adapter to G1/4"
€3.89*
PUZ Alphacool decoupling set Eheim/Hydor 4 buffer
€3.48*
This high performance ceramics centrifugal pump is designed for continuous use without... more
This high performance ceramics centrifugal pump is designed for continuous use without compromise. The base plate of the device is variable, which means there are numerous mounting options. The Eheim centrifugal pump 1046 is the ideal "motor" for your water cooling system, it is compact, tried and tested, quiet and works very reliably. We therefore recommend this pump as a standard pump, as its performance is completely sufficient.
To mount universal hose connections, use our Eheim adapters.
This variant of the Eheim pump is delivered as a fully ceramic version with a ceramic axle and ceramic bearings. This design ensures long-term smooth running.
This pump is also suitable for use in ice bathing . With sufficient flow, it can be used in conjunction with a Hailea Chiller to effectively cool the water before ice bathing. If you intend to use it for this purpose, please also order the appropriate connection adapters with
Technical data:
Pump capacity: 300 l/h
Discharge head: 1.20 mWs
Power consumption: 5 W
Dimensions L x W x H mm: 145 x 75 x 103
Ceramic axle and ceramic bearing
EHEIM No.: 1046-790
Attention! This pump is delivered without accessories as shown in the picture!
Note: Tightening the pump adapter too much can cause the plastic cover to break. By placing the O-ring in place and turning it slightly by hand, the seal is ensured.
Hersteller: Eheim
Dimensions: 145 x 75 x 103mm
Maximum discharge head: Standard (less than 2m)
Maximum system temperature: 35°C
Maximum flow: 300 l/h, 480 l/h
Color: Black
Tension: 220V AC
Power connection: Power plug
Water outlet: G1/8" internal thread
Water inlet: G3/8" internal thread
Approved liquids: Water/glycol mixture
Power consumption: 5W
Material: Ceramics, Plastic
€3.48 *
Alphacool Y-Splitter aRGB 3-Pin to 3x 3-Pin 60cm
€5.99 *
Alphacool Y-Splitter aRGB 3-Pin to 2x 3-Pin 60cm
€4.68 *
€2.68 *
Delivery date: in 2 - 3 weeks
Alphacool Eiszapfen angle adapter 90° rotatable G1/4 AG to G1/4 IG - 4pcs Set Deep Black
Content 4 Stück (€6.75 * / 1 Stück)
€26.98 *
Delivery date: in 3 - 4 month
Alphacool Eiszapfen 16/10mm screw-on nozzle 90° rotatable G1/4 - 4pcs Set Chrome
€29.98 *
Alphacool Apex Liquid Blue UV-active 1000ml
Content 2 Stück (€12.99 * / 1 Stück)
€25.98 *
Content 300 Zentimeter (€2.66 * / 100 Zentimeter)
Content 6 Stück (€3.00 * / 1 Stück)
Alphacool Ice Water Crystal Clear UV-active Ready Mix 1000ml
56%
MKA Alphacool AlphaCord Sleeve 4mm - 3,3m (10ft) - Black (Paracord 550 Typ 3) 330cm
Alphacool AlphaCord Sleeve 4mm - 3.3m (10ft) - Black (Paracord 550 Type 3) 330cm
€1.98 * €4.47 *
