Alphacool VPP Apex pump - G1/4 IG incl. ice cover D5 - acrylic V.3
  • 13306
  • 4250197133067
  • 1 kg
The Alphacool Apex VPP is a powerful pump. Via the 4-pin fan connector, the speed of the pump... more
The Alphacool Apex VPP is a powerful pump. Via the 4-pin fan connector, the speed of the pump can be read and controlled via PWM signal. The Apex VPP is supplied with power via the SATA connector. In this version, it is supplied with the Eisdecke.
Technical data pump
Dimensions (L x W x H)65 x 65 x 41mm
Material pump coveraluminium
Material axleceramics
Connections4-Pin PWM | SATA
Cable lengths4-Pin PWM - 48cm | SATA - 48cm
Starting voltage12V DC
Maximum pumping head4,25m
Maximum flow rate340L/h
Weight276g
Technical data Eisdecke
Dimensions (L x W x H)80 x 80 x 40mm
imensions with stands (L x W x H)83 x 80 x 87mm
MaterialAcrylic
Threads5x 1/4" Gewinde
Colortransparent
Dimensions: 95 x 45 x 80mm
Maximum discharge head: Good (2 to 4m)
Maximum system temperature: 60°C
Maximum flow: 1500 l/h
Possible control range: 8-24V DC
Color: Transparent
Tension: 12V DC
Power connection: 4Pin
Water outlet: G1/4" internal thread
Water inlet: G1/4" internal thread
Approved liquids: Water/glycol mixture
Power consumption: 23W
Material: Acrylic, Ceramics, Plastic
Content 6 Stück (€2.66 * / 1 Stück)
Alphacool HF screw plug G1/4 - Deep Black
€1.68 *
Liefertermin: in 8 - 9 Wochen
Liefertermin: in 9 - 10 Tagen
WZS Spritzflasche 250ml PE-LD
spray bottle 250ml PE-LD
€3.59 *
WAC Alphacool Core 1 Silver
€99.98 *
Alphacool Eiszapfen 13/10mm screw-on nozzle G1/4 - White Sixpack
Alphacool Eiszapfen 16/10mm screw-on nozzle 90° rotatable G1/4 - 4pcs Set Chrome
Content 4 Stück (€7.00 * / 1 Stück)
€27.98 *
€29.98 *
€1.89 *
Liefertermin: in 2 - 3 Wochen
Alphacool HardTube 16/13mm Acrylic (PMMA) Clear 80cm - Set of 4 (320cm)
€26.98 *
€59.98 *
WAK Alphacool Core Geforce RTX 5080 Solid + AMP mit Backplate
Alphacool Core Geforce RTX 5080 Solid + AMP with backplate
€199.98 *
