Alphacool VPP Apex pump - G1/4 IG incl. ice cover D5 - acrylic V.3
- Article no.: 13306
- EAN: 4250197133067
- Weight: 1 kg
The Alphacool Apex VPP is a powerful pump. Via the 4-pin fan connector, the speed of the pump can be read and controlled via PWM signal. The Apex VPP is supplied with power via the SATA connector. In this version, it is supplied with the Eisdecke.
Technical data pump | |
Dimensions (L x W x H) | 65 x 65 x 41mm |
Material pump | synthetic material |
Material pump cover | aluminium |
Material axle | ceramics |
Connections | 4-Pin PWM | SATA |
Rotational speed | 2500 - 4500 RPM |
Cable lengths | 4-Pin PWM - 48cm | SATA - 48cm |
Operating voltage | 8-13V DC / 14W IP32 |
Starting voltage | 12V DC |
Maximum pumping head | 4,25m |
Maximum flow rate | 340L/h |
Maximum working temperature | 60°C |
Weight | 276g |
Color | black |
Technical data Eisdecke | |
Dimensions (L x W x H) | 80 x 80 x 40mm |
imensions with stands (L x W x H) | 83 x 80 x 87mm |
Material | Acrylic |
Threads | 5x 1/4" Gewinde |
Color | transparent |
Dimensions: | 95 x 45 x 80mm |
Maximum discharge head: | Good (2 to 4m) |
Maximum system temperature: | 60°C |
Maximum flow: | 1500 l/h |
Possible control range: | 8-24V DC |
Color: | Transparent |
Tension: | 12V DC |
Power connection: | 4Pin |
Water outlet: | G1/4" internal thread |
Water inlet: | G1/4" internal thread |
Approved liquids: | Water/glycol mixture |
Power consumption: | 23W |
Material: | Acrylic, Ceramics, Plastic |
Liefertermin: in 2 - 3 Wochen
Liefertermin: in 8 - 9 Wochen
