Alphacool DC-LT acrylic attachment
- Article no.: 13136
- EAN: 4250197131360
- Weight: 0,072 kg
The optimal attachment for the Alphacool DC-LT pump.
This attachment is designed so that it can be mounted on the Alphacool DC-LT pump. This makes it possible to integrate this mini pump into a water cooling circuit using ¼” connections.
The inlet connection can be attached from the side or from above. The outlet is on the opposite side.
All silent fans will be pleased that threads have been installed to enable decoupling, e.g. item number: 13701, to be used. This allows the attachment with pump to be mounted in a 3.5 inch drive bay.
But the case modders among us have also been thought of; a 5mm LED opening on the outlet side sets this lid off beautifully.
Technical data:
Dimensions (LxWxH): 49 x 49 x 24mm (without connections, without pump)
Weight: 66g
Material: Röhm Plexiglas GS
Mounting: 4x M4 thread
Connections: 3x 1/4 inch thread.
1x Alphacool attachment DC-LT Plexi
Mounting screws for the DC-LT pump
Hardwaremax
Review Center
Note: Only one of the two inlet openings is required to operate the lid. It is therefore advisable to order a screw plug for this purpose.
