Alphacool HF 14 Smart Motion Universal Copper Edition
  • 11378
  • 4250197113786
  • 0,159 kg
€41.98 *
The new SmartMotion universal cooler is a multi-talent - suitable for all common mainboard... more
The new SmartMotion universal cooler is a multi-talent - suitable for all common mainboard northbridge and southbridge chips as well as NVIDIA® and ATI® GPU chips*. The cooler can also be used on the video chip of NVIDIA graphics cards or for other special solutions.
This is made possible by the extremely flexible and movable mounting system, in which the mounting brackets are pivotably mounted. If that is not enough, an additional mounting bracket is included in the delivery so that you can cover all conceivable mounting distances.
*The possible hole spacing and swivel radii of the different supports can be
from the PDF document.
The best thing about it: to change the supports, the cooler does not have to be dismantled, only the decorative panel has to be removed. A separate decorative panel is supplied for continuous supports. If you need more supports in the future, you can simply buy them later and therefore do not need a new cooler.
The performance is also remarkable: milled cooling bars in the base plate made of pure copper enable high cooling performance with a considerable flow rate of 5 liters per minute - sufficient for all high-flow systems.
The G ¼" connection distance is 24mm from hole center to hole center, enough for connections with a large outer diameter.
A notice:
The Alphacool HF 14 Smart Motion is also compatible as a chipset cooler for AMD X570 motherboards. However, please note that the connectors on the cooler may collide with the graphics card in the first or second PCIe slot.
Features at a glance:
  • Universal chipset and GPU cooler
  • Lid made of durable POM
  • E-CU copper base plate with milled cooling fins
  • Mounting bracket made of 3mm thick aluminum with aluminum trim
Technical data:
(WxLxH): 35 x 40 x 15mm (with screw head 16.65mm)
Compatible with 45 to 75mm hole spacing
Flow rate: 5 liters per minute
Connection thread: G ¼"
Weight: 46g
  • Smart Motion Universal
  • Screw set
  • Aperture
  • 1 mounting bracket
You can download the assembly instructions here.
Motherboard compatibility list
Alphacool MCX Cap - Black Set of 10
Content 10 Stück (€0.32 * / 1 Stück)
€3.18 *
WAO Alphacool MCX one
Alphacool MCX one
€3.18 *
€1.19 *
€4.97 *
WAO Alphacool MCX ram
Alphacool MCX ram
Alphacool MCX one
WAC Alphacool Core 1 White
€115.98 *
€3.47 *
€34.98 *
€27.98 *
