Alphacool Ice Comb X24 - 3mm clear - 2 pieces
  • 24748
  • 4250197247481
  • 0,002 kg
€0.99 * €3.89 * (74.55% Saved)
Content: 2 Stück (€0.50 * / 1 Stück)
What is that?
Highlights
  • Nylon is flexible and cannot break
  • Easy installation without modifications
  • Simple and clean laying of cables
  • Material: Polyester
  • Variant: X24 Flat
  • Dimensions: 51.5 x 8 x 2mm
  • Color: Clear
Scope of delivery
  • Alphacool Ice Comb X24 Flat - 3mm clear - 2 pieces
Datasheet
Assembly instructions
57%
Alphacool Laing DDC-SilentBox bottom
€1.99 * €4.59 *
83%
€1.49 * €8.98 *
52%
and Conditions Alphacool Cape Corp Coolplex HF Metal 15 - Chrome
€19.99 * €41.39 *
75%
€0.99 * €3.89 *
€0.99 *
75%
Alphacool Eiskamm X4 Flat - 3mm clear - 4 pieces
€0.99 * €3.89 *
75%
KAB Alphacool Eiskamm X4 - 3mm clear - 4 Stück EOL
Alphacool Ice Comb X4 - 3mm clear - 4 pieces
€0.99 * €3.89 *
78%
€0.99 * €4.49 *
86%
€0.99 * €6.96 *
67%
Alphacool Eiskamm X5 Flat - 3mm clear - 4 pieces
€0.99 * €2.99 *
€0.99 * €4.89 *
Alphacool Eiskamm Alu X8 - 4mm silver - 4 pieces
€0.99 *
KAB Alphacool Eiskamm Alu X24 - 4mm black - 2 Stück PHT EOL
Alphacool Eiskamm Alu X24 - 4mm black - 2 pieces
€0.99 * €5.02 *
Alphacool Y-Splitter aRGB 3-Pin to 4x 3-Pin 30cm
€5.99 *
Alphacool Y-Splitter 3-Pin to 4x 3-Pin 30cm
Content 30 Zentimeter (€8.37 * / 100 Zentimeter)
€2.51 * €3.58 *
Alphacool fan cable 3-Pin to 3-Pin extension 60cm
Content 60 Zentimeter (€2.90 * / 100 Zentimeter)
€1.74 * €2.48 *
Alphacool fan cable 3-Pin to 3-Pin extension 30cm
Content 30 Zentimeter (€5.30 * / 100 Zentimeter)
€1.59 * €2.28 *
€21.98 *
56%
Alphacool AlphaCord Sleeve 4mm - 3.3m (10ft) - White (Paracord 550 Type 3) 330cm
€1.98 * €4.47 *
78%
Alphacool Eiskamm Alu X4 Flat - 4mm blue - 4 pieces
€0.99 * €4.59 *
87%
Alphacool Eiskamm Alu X12 - 4mm blue - 4 pieces
€0.99 * €7.89 *
€0.99 *
€0.99 * €5.02 *
90%
Alphacool Eiskamm Alu X16 - 4mm silver - 4 pieces
€0.99 * €9.94 *
75%
€0.99 * €3.99 *
€0.99 * €5.02 *
Content 320 Zentimeter (€7.81 * / 100 Zentimeter)
€24.98 *
