Alphacool Ice Case Basic - bending kit
- Article no.: SZ
- EAN: 4250197136259
- Weight: 3,252 kg
- Available: Es sind weniger als 5 Artikel verfügbar
More and more water cooling fans are opting for HardTubes for aesthetic and practical reasons. It is important that the tubes are bent to fit the water circuit. To ensure this is successful, the Alphacool Eiskoffer Basic contains a large number of tools to bend the HardTubes optimally. All you need is a hot air gun and a saw to cut the HardTubes to the desired length. This not only ensures that the water cooling system looks great, but also makes assembling the water cooling system much easier.
The case contains two different sized circular arc feeders and two multi-arc feeders. These make it easy to create any angle you want. All feeders are designed for HardTubes with an outside diameter of 13 or 16 mm. Two fitting stops are included so that you can measure the correct length when bending. These simulate the depth of the icicle fittings. Two additional feeders with pin stops can be used in a variety of ways. Either as support to achieve several bending radii at the same time, or as an end stop point.
All supports and stops can be screwed onto any wooden board. The matching wood screws are included in the set. To ensure that the HardTubes can be bent successfully for water cooling, there are two 80 cm long bending inserts for HardTubes with an inner diameter of 10 and 13 mm. This prevents the HardTubes from kinking when bending. Of course, a deburrer is a must in a set like this. This is important for rounding off the cut edges of the HardTubes. This is the only way to push the HardTube cleanly into the fitting without the risk of damaging the O-rings in the fitting. The functions of all the tools included are described in detail in the enclosed instructions.
All the tools come in a sturdy flight case. To ensure that the tools are safely stored in the flight case, all the tools are embedded in thick foam. This means that the tools can always be neatly packed back at the end of the job and the case can be neatly stowed away in the desired place.
With the Eiskoffer Basic you get a perfect basis to design the hard tubes of the water cooling system according to your own wishes.
- Dimensions: 440 x 300 x 97
- Material bending feeder: Nylon
- Compatible HardTube sizes: 13 and 16mm outer diameter
Scope of delivery
- 1x Alphacool Eiskoffer Basic - bending kit
