Alphacool Eiskoffer Basic - bending kit
  • 29132
  • 4250197136259
  • 3,252 kg
€99.98 *
18510 Alphacool Eisrohr 13/10mm Acryl (PMMA) HardTube satin 80cm - 4pcs
€23.98*
29125 Alphacool pit saw for Acryl/PETG tubes 35cm
€16.98*
18526 Alphacool HardTube 12/10mm Acryl clear 60cm - 4pcs
29133 Alphacool Eiskoffer - measuring kit
€24.98*
29134 Alphacool Eiskoffer - HardTube saw tool
€15.98*
90342 Alphacool Eiskoffer - gloves size 10
€7.98*
90363 Alphacool Eiskoffer - bending plate
€19.98*
29111 Alphacool HardTube Heat Gun Pro 2000W
€17.98*
There has been a huge increase in fans of water cooling and a lot rely on HardTubes for... more
There has been a huge increase in fans of water cooling and a lot rely on HardTubes for aesthetic and practical reasons. It is important that the tubes are bent with precision to fit the loop perfectly. To achieve this, the Alphacool Eiskoffer Basic contains several tools to bend the HardTubes optimally. Only a hot air gun and a saw are needed to cut the HardTubes to the desired length. Using the Eiskoffer Basic will ensure that you can create perfect bends like a professional. It also takes the guess work away from the build, meaning the assembly of the water cooling will be much easier.
The EIskoffer Basic contains two circular mandrels of different sizes and two multi-angle mandrels. This makes it easy to make all desired angles. All mandrels are designed for HardTubes with an outer diameter of 12, 13 or 16 mm. Two fitting stops are included so that the correct length can be measured immediately during bending. These simulate the depth of the Eiszapfen fittings. Two further mandrels with pin stop can be used in a variety of ways. Either as a support create multiple bending radii simultaneously, or as an end stop point.
All mandrels and stops can be screwed onto any wooden board. The matching wood screws are included in the set. Two 80 cm long bending inserts for HardTubes with 10 and 13 mm inner diameter are included. This prevents the HardTubes from kinking whilst bending. Of course, such a set should not be without a deburring tool. This is important to round of the edges of the HardTubes after you have cut them. This ensures that the tube will push into the fitting easily and makes sure that you won’t damage the o-rings in the fitting when you push it in. The functions of all included tools are described in detail in the enclosed manual.
The entire tool set comes in a sturdy flight case with thick foam to ensure that all the tools are kept safe and complete. This means that the tools can always be neatly packed back at the end of the work and the case can be neatly stowed in the desired place.
The Eiskoffer Basic is the perfect companion for bending HardTube and will allow you to bend like a professional in no time!
Technical Details
  • Dimensions (LxWxH): 440 x 300 x 97mm
  • Material mandrels: Nylon
  • Compatible tube sizes: 13 and 16mm inner diameter
Scope of Delivery
  • 1x Alphacool Eiskoffer Basic - bending kit
WZS Gedore Schlauchklemmenzange 132-3
€44.01 *
WZS DREMEL® SC Diamant Trennscheibe (EZ SpeedClic)
€21.56 *
ZSO Alphacool Eiskoffer - Winkelanleger 13mm in 45°
Alphacool Eiskoffer - Mandrel 13mm 45°
ZSO Alphacool Eiskoffer - Winkelanleger 13mm in 90°
Alphacool Eiskoffer - Mandrel 13mm 90°
€23.98 *
Leak Testing Tool incl. Pump
€34.98 *
SZ Alphacool Eiskoffer - Biegeplatte
SZ Alphacool Eiskoffer - measuring kit
€24.98 *
SZ Alphacool HardTube Heat Gun Pro 2000W
€17.98 * €24.98 *
Alphacool Core 1 Aurora Black
€119.98 *
ANS Alphacool Eiszapfen 16mm HardTube Anschraubtülle 90° drehbar G1/4 für Acryl/Messingrohre - 4pcs Set Deep Black
Alphacool Eiszapfen 16mm HardTube compression fitting 90° rotatable G1/4 für Acryl/Brass tubes - 4pcs Set Deep Black
Content 4 Stück (€12.50 * / 1 Stück)
€49.98 *
€4.98 *
SZ Alphacool Apex Heat Gun mit LCD 2000W 80-650°C
Apex Heat Gun with LCD 2000W 80-650°C
€39.98 *
€2.98 *
RAD Alphacool NexXxoS ST30 Full Copper 360mm Radiator V.2
Alphacool NexXxoS ST30 Full Copper 360mm radiator V.2
€79.98 * €92.97 *
ZSO Alphacool Eiskoffer - Handschuhe Gr. 10
€7.98 * €10.98 *
SZ Alphacool Eiskoffer - HardTube saw tool
Content 35 Zentimeter (€48.51 * / 100 Zentimeter)
Alphacool Eisrohr 16/13mm Acryl (PMMA) HardTube satin 80cm - 4pcs
Content 320 Zentimeter (€11.56 * / 100 Zentimeter)
€36.98 *
Liefertermin: in 7 - 8 Wochen
€23.98 *
€26.98 *
WZS Spritzflasche 1000ml PE-LD
€6.19 *
WZS Spritzflasche 500ml PE-LD
€4.19 *
WAK Alphacool Core RX 7900XTX Merc 310 mit Backplate
Alphacool Core RX 7900XTX Merc 310 with Backplate
€199.98 *
Liefertermin: in 2 - 3 Wochen
Alphacool Eiszapfen 13mm HardTube compression fitting 90° rotatable G1/4 for Acryl/Brass tubes - 4pcs Set Deep Black
Content 4 Stück (€11.75 * / 1 Stück)
€46.99 *
WAK Alphacool Eisblock Aurora GPX-N Acryl Active Backplate 3090/3080 Reference EOL
€49.98 * €86.98 *
Content 4 Gramm (€3,995.00 * / 1000 Gramm)
L12 Alphacool Core 120mm Lüfter PWM 4000rpm (120x120x25mm)
Alphacool Core 120mm fan PWM 4000rpm (120x120x25mm)
€10.98 *
€6.28 *
WAH Alphacool HDX Apex Acryl aRGB M.2 2280 SSD Kühler
Alphacool HDX Apex Acrylic aRGB M.2 2280 SSD Cooler
RAD Alphacool NexXxoS HPE-45 Full Copper 280mm Radiator
€114.98 *
RAD Alphacool NexXxoS HPE-45 Full Copper 360mm Radiator
€109.98 * €124.99 *
€44.98 *
Content 10 Stück (€0.56 * / 1 Stück)
€5.58 *
