Alphacool Eiszapfen 13mm HardTube screw-on nozzle 90° rotatable G1/4 - Deep Black
  • 17393
  • 4250197173933
  • 0,074 kg
Version: 90° screw-on nozzle 13mm
This connector has a 1/4" thread on one side and is therefore compatible with 95% of all components. The other side is suitable for a 13mm acrylic and brass tube. In the middle, this connector is angled at 90° to avoid complicated hose routes. For maximum flexibility, the side with the thread can be rotated.
  • Material: Brass
  • Colour: Deep Black
dimension
  • Length: 42.5mm
  • Width: 21mm
Scope of delivery
  • 1x Alphacool Eiszapfen 13mm HardTube screw-on nozzle 90° rotatable G1/4 for acrylic brass tubes - Deep Black
Here you will find an interactive overview of all Alphacool connections.
€20.98 *
€37.98 *
€23.98 *
€25.98 *
Delivery date: in 6 - 7 weeks
Content 240 Zentimeter (€7.49 * / 100 Zentimeter)
Alphacool HardTube 13/10mm 90° acrylic (PMMA) 20/40cm
Content 60 Zentimeter (€18.30 * / 100 Zentimeter)
€10.98 *
