Alphacool Aurora HardTube LED ring 13mm chrome - RGB
  • 15353
  • 4250197153539
  • 0,012 kg
15315 Alphacool Aurora LED RGB Controller compact
€4.97*
18565 Alphacool HardTube 13/10mm 90° Acryl (PMMA) 10/30cm
€7.98*
The Alphacool Aurora HardTube RGB LED Ring is the perfect solution for illuminating the... more
The Alphacool Aurora HardTube RGB LED Ring is the perfect solution for illuminating the HardTubes or water cooling tubes. Simply slide the Aurora HardTube RGB LED ring over the tube or HardTube and it will shine perfectly. The connection is made via a 4-pin male RGB connector. The ring itself is made of pure brass. Inside the ring are 3 RGB LEDs and two O-rings. The O-rings are used to hold the Aurora HardTube RGB LED ring in its desired position and to prevent scratches when passing over the HardTubes.
Using these, completely new possibilities of lighting for your own water cooling are available. The classic RGB LED strips or RGB fans can be connected to achieve a harmonious and impressive appearance. Combined with the Alphacool Eiswater liquids for the fluid, you are limited only by your imagination for the colourful effects.
The Alphacool Aurora HardTube RGB LED rings are compatible with all common RGB controllers. They can also be used with any motherboard and their included controllers including ASUS ROG Aura Sync, ASRock RGB LED, MSI Mystic Light and GIGABYTE RGB Fusion. Depending on the connection, a suitable adapter may be required. The simplest way to control the LEDs is by using of the Alphacool Aurora RGB controller.
Technical Details
  • Size: for 13mm HardTubes
  • Dimensions (DxH): 22 x 20 mm
  • Casing: plastic chrome
  • LED colour: RGB
  • Cable: RGB Male connector 30 cm
Scope of Delivery
  • 1x Alphacool Aurora HardTube LED ring 13mm chrome - RGB
SZ Alphacool Aurora HardTube LED Ring 13mm Deep Black - RGB
Alphacool Aurora HardTube LED ring 13mm deep black - RGB
WACZ Alphacool Aurora XPX RGB Frame - Chrome
Alphacool Aurora XPX RGB frame - chrome
€8.98 * €9.95 *
SZ Alphacool Aurora HardTube LED Ring 16mm Chrome - RGB
Alphacool Aurora HardTube LED ring 16mm chrome - RGB
€44.98 *
Liefertermin: in 2 - 3 Wochen
L12 Alphacool Rise Aurora 120 mm Lüfter (120x120x25mm)
€11.98 * €18.98 *
Alphacool M3 Spacer 34mm
€3.48 *
Alphacool Universal feet for radiators
Content 2 Stück (€12.49 * / 1 Stück)
€24.98 *
RAD Alphacool NexXxoS ST25 Full Copper 360mm Radiator
Alphacool NexXxoS ST25 Full Copper 360mm radiator
€64.99 * €77.98 *
Alphacool connection cable 3pin to 3pol Digital RGB - 15cm
€4.48 *
WACZ Alphacool Aurora XPX Digital RGB Frame - Chrome
Alphacool Aurora XPX Digital RGB frame - chrome
RAD Alphacool NexXxoS XT45 Full Copper 360mm Radiator V.2 PHT EOL
Alphacool NexXxoS XT45 Full Copper 360mm radiator V.2
€89.98 * €109.98 *
KAB Alphacool Y-Kabel RGB 4pol auf 3x 4pol inkl. Stecker - Schwarz 30cm
Alphacool y-cable RGB 4pol to 3x 4pol 30cm incl. connector - black
Content 30 Zentimeter (€8.27 * / 100 Zentimeter)
€2.48 * €6.49 *
WAC Alphacool Eisblock XPX CPU - polished Clear Version
Alphacool Eisblock XPX CPU - polished clear version
€49.98 * €59.98 *
PUM Alphacool Eisbecher D5 250mm Acetal inkl. 1x Alphacool VPP655
€129.98 * €173.72 *
Alphacool Eiszapfen 13mm HardTube compression fitting G1/4 - knurled - chrome sixpack
€33.98 *
S13 Alphacool HardTube 13/10mm Acryl (PMMA) Klar UV-Blau 60cm - 4er Set (240cm)
Alphacool HardTube 13/10mm Acryl clear UV-Blue 60cm - 4pcs
Content 240 Zentimeter (€3.00 * / 100 Zentimeter)
€7.19 * €16.29 *
Alphacool HardTube 13/10mm Acryl clear 80cm - 4pcs
Content 320 Zentimeter (€6.24 * / 100 Zentimeter)
Liefertermin: in 7 - 8 Wochen
AGZ Alphacool Acryl Tube 60x200mm (DxH)
Alphacool Acryl tube 60x200mm (DxH)
€7.98 * €18.98 *
Alphacool Silver Grease 0,5g
Content 0.5 Gramm (€3,340.00 * / 1000 Gramm)
€1.67 *
