Alphacool HDX Pro Air - M.2 NVMe 2280 SSD
  • 11770
  • 4250197117708
  • 0,051 kg
WAR Alphacool Ice Layer Thermal Pad - 11W/mK 120x20x0.5mm - 2 pieces PHT EOL
€14.98*
WAR Alphacool Ice Layer Thermal Pad - 11W/mK 120x20x1mm - 2 pieces PHT EOL
€21.98*
WAH Alphacool HDX - M.2 SSD M01 - 80mm - Black EOL
€6.99*
12860 Alphacool Eisschicht Light thermal pad - 7W/mK 120x20x0,5mm
€5.99*
12861 Alphacool Eisschicht Light thermal pad - 7W/mK 120x20x1mm
€6.99*
SSDs in M.2 format are becoming increasingly popular. The high transfer rates and extremely low... more
SSDs in M.2 format are becoming increasingly popular. The high transfer rates and extremely low access times allow you to work or play on your PC faster and more effectively. To ensure that you can use the full performance of the M.2 SSD permanently, Alphacool offers the HDX PRO Air M.2 SSD cooler.
Why an M.2 cooler?
Due to their design, M.2 SSDs are only able to reach their maximum performance for a short period of time. The controller chip heats up extremely quickly and begins to throttle the performance of the M.2 SSD early on to prevent overheating. Independent tests have shown that the transfer rates of uncooled M.2 SSDs can drop after just 30 seconds during write operations. During read operations, throttling usually occurs a few seconds later. With the Alphacool HDX Pro Air M.2 SSD cooler, you can use the maximum performance of the SSD over a much longer period of time. This is clearly noticeable during longer read and write operations.
How do I install the cooler?
The HDX Pro Air M.2 cooler is compatible with M.2 SSDs that are equipped on one or both sides. All you have to do is place the corresponding thermal pad on the lower cooling plate, then place the M.2 SSD on top. Another thermal pad is then placed on the top of the M.2 SSD, on which the cooler is placed. To hold the whole thing together, 4 clips are attached on each side to hold everything together. Installation on the mainboard is then carried out as usual.
Cooler dimensions: 68 x 22 x 6.4 mm
Backplate dimensions: 68.8 x 22 x 2 mm
Material: aluminum
Compatible with: M.2 2280 SSDs
Download data sheet PDF: Alphacool HDX Air Pro M.2 2280 SSD
Download manual: Alphacool HDX Air Pro M.2 2280 SSD
22%
WAH Alphacool HDX - M.2 SSD M01 - 80mm - Schwarz EOL
€6.99 * €8.98 *
Alphacool GPU RAM Copper Heatsinks 6.5x6.5mm - 10 pcs.
Content 10 Stück (€1.00 * / 1 Stück)
ZSO Alphacool Tasse schwarz
Alphacool Mug black
Alphacool Apex Thermal Pad Soft 18W/mk 120x20x1,5mm
Content 24 cm² (€2.08 * / 1 cm²)
€49.98 *
€2.48 *
€1.89 *
€5.99 *
€4.97 *
€6.49 * €8.98 *
