Alphacool Core Geforce RTX 5090 Reference with backplate
- Article no.: 10242
- EAN: 4250197102421
- Weight: 1,7 kg
Delivery date: in 2 - 3 weeks
- Inno3D GeForce RTX™ 5090 iChill Frostbite (C50903-32D7X-1759FB)
- Inno3D GeForce RTX™ 5090 iChill X3 (C50903-32D7X-175967H)
- Inno3D GeForce RTX™ 5090 X3 (N50903-32D7-17593928)
- Inno3D GeForce RTX™ 5090 X3 OC (N50903-32D7X-17593928)
- MSI GeForce RTX™ 5090 32G VENTUS 3X OC (MS-V530 VER:1.1)
Technical data cooler | |
Dimensions total (L x W x H) | 201,40 x 148,57 x 34,38mm |
Material cooler top | Acrylic |
Material terminal | Acetal |
Material Connection thread | Brass |
Pressure tested | 0,8 bar |
Threads | 4 x G1/4" |
Thickness cooler bottom | 3,25mm |
Illumination | digital aRGB LEDs |
Number of digital aRGB LEDs | 9 |
Color | transparent |
Technical data backplate | |
Dimensions (L x W x H) | 201,40 x 120 x 6mm |
Thick backplate without spacers | 3mm |
Material | Aluminium |
Material base plate: | Aluminum |
Dimensions: | 201.40 x 148.57 x 34.38mm |
Connection: | 4x G1/4" |
Hardware manufacturers: | NVIDIA |
Hardware model: | RTX 5090; |
Delivery date: in 7 - 8 weeks
