Alphacool Eisblock Aurora Acryl RTX 4070TI Reference with backplate
- Article no.: 13550
- EAN: 4250197135504
- Weight: 1,135 kg
The next generation - the Alphacool Eisblock Aurora water cooler for Geforce RTX 4XXX graphics cards. In order to dissipate the enormous heat of this graphics card generation in the best possible way, numerous optimizations have been made to the water cooler compared to the previous model. The fin structure was adapted and enables a very good water flow while increasing the cooling surface. The modified jet plate with improved inflow engine ensures an optimal distribution of the water on the cooling fins.
Technical Highlights
Chrome-plated copper
Design
Thermal paste & thermal pads
- Nvidia GeForce RTX 4070 Super Founders Edition, 12 GB GDDR6X
- Inno3D GeForce RTX 4070 Ti iCHILL X3, 12GB GDDR6X (C407T3-126XX-186148H)
- Inno3D GeForce RTX 4070 Ti X3 OC, 12GB GDDR6X (N407T3-126XX-186148N)
- Inno3D GeForce RTX 4070 Ti X3, 12GB GDDR6X (N407T3-126X-186148N)
- Inno3D GeForce RTX 4070 Ti SUPER Twin X2 OC White, 16GB GDDR6X (N407TS2-166XX-186156W)
- Inno3D GeForce RTX 4070 Ti SUPER Twin X2 OC, 16GB GDDR6X (N407TS2-166XX-186156N)
- Inno3D GeForce RTX 4070 Ti SUPER Twin X2, 16GB GDDR6X (N407TS2-166X-186156N)
Technical data cooler | |
L x W x H | 182,13 x 120,8 x 42,93mm |
Pressure tested | 0,8 bar |
Threads | 4 x G1/4" |
Illumination | digital aRGB LEDs |
Number of digital aRGB LEDs | 8 |
Technical data backplate | |
L x W x H | 182,13 x 96,4 x 5mm |
Material | aluminium |
Color | black |
Made in: | China |
Cooler type: | Complete cooler |
Material base plate: | Copper; |
Material Lid: | Acrylic; |
SLI compatible: | Yes |
Dimensions: | 182,13 x 120,8 x 42,93mm |
Connection: | 4x G1/4" |
Hardware manufacturers: | NVIDIA |
Hardware model: | RTX 4070 Ti; |
Notice: | Compatible up to 16/13mm straight; Compatible up to 19/13mm angled; |
