Alphacool Eisblock Aurora Geforce RTX 4090 Aorus Master - Gaming with Backplate
  • 13476
  • 4250197134767
  • 1,82 kg
€159.98 *
90334 Alphacool Eisplateau Anti-Static work- and mounting mat 120x60cm
€59.98*
12982 Alphacool Eisbaer TPV Extension kit (tube and fittings)
€15.39*
€14.98*
11991 Alphacool Core Storm 420mm XT45 water cooling Set
€379.98*
11996 Alphacool Eisbaer LT360 Aurora HPE CPU AIO
€179.98*
13036 Alphacool Apex 17W/mK Thermal grease 4g
€15.98*
The next generation - the Alphacool Eisblock Aurora water cooler for Geforce RTX 40XX graphics... more
The next generation - the Alphacool Eisblock Aurora water cooler for Geforce RTX 40XX graphics cards. In order to dissipate the enormous heat of this graphics card generation in the best possible way, numerous optimizations have been made to the water cooler compared to the previous model. The fin structure was adapted and enables a very good water flow while increasing the cooling surface. The modified jet plate with improved inflow engine ensures an optimal distribution of the water on the cooling fins.
Technical Highlights
Chrome-plated copper
Design
The Aurora design of the Geforce RTX 40XX Eisblock generation is visually calmer and simpler. Only one O-ring runs around the entire cooler. The design around the cooling fins and jetplate makes for a cleaner look. The illumination of the digitally addressable RGB LEDs is even better distributed throughout the cooler as a result of the chrome plating. The terminal's design is in line with the classic Aurora design.
Thermal paste & thermal pads
The included thermal compound is Alphacool's Subzero. With a thermal conductivity of 16 W/mK, it is one of the highest performing thermal pastes on the market. The electrically non-conductive thermal compund is particularly well suited for high contact pressures, but can still be processed perfectly due to its viscosity of 850.000 TF. Alphacool Soft Pads with 1mm thickness are used on the voltage converter and the graphics memory. The thermal conductivity of the pads is 7 W/mK. The pads for the back of the PCB are 3mm thick and have a thermal conductivity of 3 W/mK.
Attention: Not compatible with the PCB V1.1!
- Gigabyte AORUS GeForce RTX 4090 Master 24G, 24GB GDDR6X (GV-N4090AORUS M-24GD)
- Gigabyte GeForce RTX 4090 Gaming OC 24G, 24GB GDDR6X (GV-N4090GAMING OC-24GD)
Technical data cooler
L x W x H233,3 x 152,46 x 33,9mm
Material cooler topacrylic
Threads4 x G1/4"
Thickness cooling fins0,4mm
Distance cooling fins0,4mm
Illuminationdigital aRGB LEDs
Power digital aRGB LEDs5V
Number of digital aRGB LEDs12
Technical data backplate
L x W x H233,3 x 127,96 x 6mm
Materialaluminium
Material Bodenplatte: Kupfer;
Hardware Hersteller: NVIDIA
Material Deckel: Acryl;
SLI kompatibel: Ja
Kühlertyp: Komplettkühler
Hinweis: Kompatibel bis 16/13mm gerade;Kompatibel bis 19/13mm gewinkelt;
Anschluss: 4x G1/4"
Hardware Modell: RTX 4090;
Abmessungen: 233,3 x 152,46 x 33,9mm
WAK Alphacool Eisblock Aurora Acryl GPX-A Radeon 5600/5700 XT Gaming X EOL
€69.99 * €129.97 *
WAK Alphacool Eisblock Aurora Acryl GPX-A Radeon 5600/5700 XT Red Devil EOL
€74.07 * €99.98 *
WAK Alphacool Eisblock Aurora Acryl GPX-A Radeon RX 5700 XT Taichi X8 8G OC EOL
€69.99 * €99.98 *
WAK Alphacool Eisblock Aurora Acryl GPX-A Radeon RX 5700 XT Thicc II / III EOL
€69.98 * €109.98 *
Content 1 Gramm (€7,980.00 * / 1000 Gramm)
RAD Alphacool NexXxoS HPE-45 Full Copper 360mm Radiator
€109.98 * €124.99 *
PUM Alphacool Core 200 Aurora Ausgleichsbehälter Acetal/Acryl mit VPP Pumpe
Alphacool Core 200 Aurora Reservoir Acetal/Acryl with Apex Pump
€89.98 * €124.99 *
WAC Alphacool Eisblock XPX Aurora - Acryl Chrome Digital RGB
€54.98 * €65.99 *
€99.98 *
KAB Alphacool Apex PCI-e 4.0 Riser Kabel - 20cm
Alphacool Apex PCI-e 4.0 Riser cable - 20cm
Content 20 Zentimeter (€374.90 * / 100 Zentimeter)
€74.98 *
€65.99 * €89.23 *
€44.98 *
WAK Alphacool Eisblock Aurora Acryl GPX-N RTX 3080/3090 FTW3 mit Backplate EOL
Alphacool Eisblock Aurora Acryl GPX-N RTX 3080/3090 FTW3 with Backplate
€89.99 * €159.97 *
ANK Alphacool HF Schnellverschlusskupplungsset G1/4 AG/AG
Alphacool HF quick release connector kit G1/4 OT/OT
€11.98 *
Leak Testing Tool incl. Pump
€34.98 *
AGB Alphacool Eisbecher Aurora D5 Acetal/Glas - 250mm
€99.98 *
RAD Alphacool NexXxoS ST30 Full Copper 420mm Radiator V.2
Alphacool NexXxoS ST30 Full Copper 420mm radiator V.2
€99.98 * €112.98 *
S16 Alphacool Schlauch AlphaTube HF 16/10 (3/8"ID) - Klar Meterware
Alphacool tubing AlphaTube HF 16/10 (3/8"ID) - clear
€7.48 *
Alphacool Eisrohr 13/10mm Acryl (PMMA) HardTube satin 80cm - 4pcs
€23.98 *
€38.98 *
Alphacool Eiszapfen 13/10mm compression fitting G1/4 - chrome sixpack
€33.98 *
Alphacool tubing AlphaTube HF 13/10 (3/8"ID) - clear
€23.98 *
€3.98 *
WAK Alphacool Core RX 7900XTX Red Devil mit Backplate
Alphacool Core RX 7900XTX Red Devil with Backplate
€199.98 *
KAB Alphacool PWM auf Mainboard PWM 40cm schwarz
Alphacool PWM to Mainboard PWM 40cm black
Content 40 Zentimeter (€11.20 * / 100 Zentimeter)
€4.48 *
WAC Alphacool Core 1 Aurora Silver
€119.98 *
Alphacool Core 1 Aurora Black
€119.98 *
WAC Alphacool Core 1 White
€109.98 *
WZS Alphacool Core HardTube Metall Cutter 7-31mm
€4.48 *
