Alphacool Eiszapfen 16mm HardTube screw-on nozzle 45° L-connector - Deep Black
  • 17405
  • 4250197174053
  • 0,079 kg
€8.48 *
Alphacool's Eiszapfen connection series is the high-end version of the proven connections!... more
Design: 45° screw-on nozzle 16mm acrylic brass tubes
This connector is suitable for 16mm acrylic or brass pipes on both sides. In the middle, this connector is angled at 45° to avoid complicated hose routes.
  • Material: Brass
  • Colour: Deep Black
dimension
  • Length: 46mm
  • Width: 23mm
  • Height: 36mm
Scope of delivery
  • 1x Alphacool Eiszapfen 16mm HardTube screw-on nozzle 45° L-connector acrylic brass tubes - Deep Black
Here you will find an interactive overview of all Alphacool connections.
2nd page: 16/10mm (ID 3/8" OD 5/8")
Rotatable: Yes - 360°
Color: schwarz;
Thread length: 5mm
Compatibility: Acrylic tubes;Brass tubes;Carbon tubes;
Material: Messing;
Specification: Shape: 45° angled
1st page: G1/4" external thread
Alphacool Eiszapfen 16mm HardTube screw-on nozzle G1/4 - Deep Black Sixpack
€33.98 *
Alphacool HardTube 16/13mm Acrylic (PMMA) Clear 80cm - Set of 4 (320cm)
€26.98 *
Content 240 Zentimeter (€7.91 * / 100 Zentimeter)
€38.98 *
€28.98 *
Content 320 Zentimeter (€7.81 * / 100 Zentimeter)
€24.98 *
Content 320 Zentimeter (€11.56 * / 100 Zentimeter)
€36.98 *
Delivery date: in 2 - 3 weeks
ANZ Alphacool Eiszapfen Verschlussschraube G1/4 - Deep Black
Alphacool Eiszapfen screw plug G1/4 - Deep Black
€2.68 *
Delivery date: in 9 - 10 days
Content 10 Stück (€0.17 * / 1 Stück)
€1.68 *
