Alphacool Ice Cyclone Aurora LUX Digital RGB - Kit of 3 (120x120x25mm)
- Article no.: 24804
- EAN: 4250197248044
- Weight: 0,531 kg
The Alphacool Eiszyklon Aurora LUX fan impresses with its aRGB LEDs and diffuse light elements, which distribute the light evenly. Its strengths are particularly evident on radiators, as the fan generates a high static pressure, even when it rotates more slowly. Its maximum speed is 1100 rpm. Thanks to its naturally decoupled frame, it remains quiet and calm even at this speed. Unlike many other fans, it only has one cable, which ends in a 6-pin connector. Using the Aurora LUX Digital RGB controller from Alphacool, this one cable can be used to regulate the speed as well as set the lighting effects and colors.
Technical Data:
- Fans
- Size: 120 x 120 x 25 mm
- Speed: 1100 rpm
- Static Pressure: 2.23 mm H2O
- Airflow rate: 87.32 m³/h
- Bearings: Hydraulic
- Fan/ aRGB Connector: 6-Pin
- Illumination: Digital addressable 5V RGB LEDs
- Controller
- Dimensions: 93 x 47 x 17 mm (L x W x H)
- Fan Connector: 10 x 6-pin
- Digital RGB LED strip connector: 2x JTS 4-pin
- Fan Voltage: 12V
- Digital RGB LED Voltage: 5V
- Max. Power Output: 50W
- Control Via: Remote controller
- Mounting: Adhesive Tape
Rated speed range: | 1000 - 1450 U/min |
Air conveying area: | 50 - 99 m³/h |
Air flow rate: | 98,54 m³/h |
Pressure: | 1,22mm H2O |
Color Frame: | Black |
Rated speed: | 1100 U/min |
Color Rotor: | Black |
Nominal voltage: | 12V DC |
Size: | 120mm |
Volume: | 21,0 dB(A) |
RPM signal transmission: | Yes |
Volume range: | 20 - 29,9 dB(A) |
Starting voltage: | 9,6V |
Lebensdauer (bei 25°C): | 50.000 h |
Power connection: | 3Pin |
Dimensions: | 120 x 120 x 25mm |
LED: | ARGB |
Power consumption: | 1,92W |
Fan bundle: | 3x, 4x, 9x |
Liefertermin: in 8 - 9 Wochen
