Alphacool Eisblock XPX O-Ring Kit - Black
- Article no.: WACZ
- EAN: 4250197136686
- Weight: 0,001 kg
This set includes two replacement O-rings for the Alphacool Eisblock XPX CPU water cooler. Both O-rings are located around the IN and OUT of the Eisblock XPX cooler and seal the area between the cover of the cooler and the lower part of the cooler.
This kit is available in two versions, one with black and one with transparent O-rings. The "clear" version of the Eisblock XPX CPU water cooler can be customized to suit your needs.
Dimensions of the O-rings:
- 25X2mm
- 47X2mm
